Will those Wheels Fit an IS250 AWD - Part Uno
Old 12-04-13 | 03:02 PM
  #316
SkyZ33's Avatar
SkyZ33
Can anyone help me on the size?
2010 IS250 AWD lower on Fsport spring
19 x 8.5 +33 or +38
19 x 9.5 +35 or +43
Would they fit? any fender work? Thanks!
Old 12-06-13 | 09:22 PM
  #317
reyoasian's Avatar
reyoasian
2009 IS250 AWD
Dropped on Road Magnet springs (2" drop all around) with F-Sport shocks
Am I able to run 18x9 +35 all around with 255/35R18?
I'm on 18x8.75 +35 right now no issues but:
1. not as low as road magnet (on H&R)
2. running 225/40R18
...and with this setup front wheel looks flush with fender line so more worried about the front if I go a little lower (roughly 0.7") with fatter tires (255/35 vs 225/40)
Thanks
Old 12-30-13 | 07:43 AM
  #318
huyz13's Avatar
huyz13
Hi,
I have a '09 IS 250 AWD. Did some searching here and decided I would like to have a squared, non staggered setup.
So far, my first choice are these Avant Garde Wheels M310:
http://avantgardewheels.com/m310.php
My question is, what size should I get for all 4 identical wheels if I want to keep it close to stock as possible? I'd like to keep it close to stock so that I don't have to deal with any further mod or without affecting other aspects, such as speedometer, turn radius, etc. There is no other mods to the car besides a F Sport Intake.
Thanks!
Old 01-05-14 | 09:17 PM
  #319
NickawdIs's Avatar
NickawdIs
Hey i need help i have is250 awd with 18"x9.5" +35 all around , whats the best tire setup ?
Old 01-12-14 | 06:03 PM
  #320
nitrotang's Avatar
nitrotang
Would stock IS250/350 rear OEM 18x8.5 rims fit all around? I'm lowered on H&R springs.
Old 01-13-14 | 06:37 AM
  #321
sm1ke's Avatar
sm1ke
^^ Yes.
10char
Old 01-29-14 | 03:33 PM
  #322
TamskiS250's Avatar
TamskiS250
Hey guys, I'm new to the Lexus scene and was wondering if anyone could gve me some advice as to if these wheel specs would fit my 06 is250 rwd with rolled/lipped guards and lowered on king springs std shocks.
19x9.5 +15 & 19x10.5 +15, just want to know what tyre sizes to go for that's all. Thanks
EDIT: I'm currently running Volk te37s 17x9+12 235/45/17 & 18x9.5 +22 255/40/18 fronts only scrub at full lock or unless I have a full car.
Old 01-29-14 | 03:51 PM
  #323
Fjiwan's Avatar
Fjiwan
Hey
N B here
was wondering if anyone could help me out.
Have my 2008 IS250 AWD running 18x9 with 20 offset
tires are 240/45/18
stock springs
Rolled the fenders and still getting some noise....was wondering if it was just the inside fender walls...anyone with this setup know?
Old 02-03-14 | 03:30 PM
  #324
IC3B3RG's Avatar
IC3B3RG
Ok I'm getting a headache reading all these numbers. I need help selecting snow tires.
I have G35 7 spoke wheels 18x8. Currently running 225/40/18... they are slightly stretched and I would like to minimalize that stretch. Should I go with a higher side wall or a wider tire or both?
I was thinking 235/45/18 but I am not sure if that will rub or not. Any help is appreciated. This is for winter.
Summer I run 245/40/18 on 18x8 g-spider wheels.
Thanks in advanced!
Old 02-08-14 | 05:40 AM
  #325
SOSNOB's Avatar
SOSNOB
19 x 8.5 +33 or +38
19 x 9.5 +35 or +43
Yes eazy no fender mods required go with front 235 35 19 and rear 265 30 19
my setup is
front: 19x9.5 +35 ( 235 / 35 / 19 )
rear: 19x9.5 +30 ( 265 / 30 / 19 )
i didn't do any fender mods and drive better than stock let me know if want pictures.
it just sits flash with guards no rubbing no issues at all.
Old 02-08-14 | 09:01 AM
  #326
JdSwiper's Avatar
JdSwiper
Could someone tell me if these would fit on my 2009 is250
Fronts...20x8.5, 38 offset 245/30/20 Falken tires
Rears...20x9.5, 45 offset 275/30/20 Falken tires
Old 02-08-14 | 07:11 PM
  #327
SOSNOB's Avatar
SOSNOB
the front & back will rub.
If you want change tires
front 225 35 20
rear 265 30 20
Old 02-09-14 | 05:06 AM
  #328
JdSwiper's Avatar
JdSwiper
front 225 35 20
rear 265 30 20
If i change to these tires they won't rub??
Old 02-09-14 | 07:36 AM
  #329
Kitty2IS's Avatar
Kitty2IS
Whoa those offsets ...
Old 02-10-14 | 12:08 AM
  #330
SOSNOB's Avatar
SOSNOB
Yes if you change the tires you wont have any issues but if i was you i would try back tires 275 ones the one you have now on rim, if they dont rub you can leave them and jsut change front ones because if you car is not too low i think 275 should be fine.
Quick Reply: Will those Wheels Fit an IS250 AWD - Part Uno
