Will those Wheels Fit an IS250 AWD - Part Uno
#332
Can you show me some photo please?
Are you lower on spring or OEM?
Thanks =)
Thanks =)
Yes eazy no fender mods required go with front 235 35 19 and rear 265 30 19
my setup is
front: 19x9.5 +35 ( 235 / 35 / 19 )
rear: 19x9.5 +30 ( 265 / 30 / 19 )
i didn't do any fender mods and drive better than stock let me know if want pictures.
it just sits flash with guards no rubbing no issues at all.
my setup is
#333
Okay guys, I'm about to buy a set of wheels in a day or two, so I'm hoping for a quick reply from the good people of the 2IS forum!
What tires would be best to run on 18x9.5 +30 wheels all around?? I'm on coilovers, haven't done any fender work at all. I'm hoping to run as little camber as possible.
Would 255/35/18 work, or is there a better size? And if there is, could you post pics?
Thanks in advance CL
#334
I am running the same setup on my wife's IS250 and her car is on 2in road magnets. I did need to roll he fenders in the rear and trim the rear bumper tabs
#336
Hi guys, I'm planning on buying 19" wheels for my 2008 IS250AWD, was thinking of getting 19x9.5 +30 front & 19x10.5 +22 rear. Does any one have this kind of setup? Do I need to roll fenders or get spacers, my car is lowerd 2" on Megan coilovers, I might lower it another inch & what kind of tire setup u guys recommend?
#337
It is AWD. It rides very well for the amount of drop that it gives. I get a slight vibration if i am stopped while the car is in gear but if your radio is on you may not even notice it. During slow acceleration I get a noticeable vibration around 30 but it quickly goes away. Its not enough to make me take them off. The vibration during acceleration did get a little worse once i put the 20s on
#338
#339
Bump!!!!!!!!!!!!!!!!!!!!!
Hi guys, I'm planning on buying 19" wheels for my 2008 IS250AWD, was thinking of getting 19x9.5 +30( or +22) front & 19x10.5 +22 rear. Does any one have this kind of setup? Do I need to roll fenders or get spacers, my car is lowerd 2" on Megan coilovers, I might lower it another inch & what kind of tire setup u guys recommend?
#340
Hey guys,
I have a 2011 IS250 AWD and was hoping to pick up a set of 2014 IS350 Fsport wheels.
Dimensions:
Available Size: Front 18 x 8.0 and Rear 18 x 8.5
Bolt Pattern: 5-114.3
Offset: 45 mm / 50 mm
Weight: 28.00 / 28.20 lbs
All-Season: 225/40/18 and 255/35/18 - Bridgestone Turanza EL 400 2
I plan to lower my car by 1-1.5 inches and will probably need a 25mm spacer (i think?) for a more flush appearance. Is this setup OK with the AWD system?
Thanks!
Dimensions:
Thanks!
#341
Let's try this again
Xxr 527
18x 8.75 20mm front or 35mm
18x 8.75 20mm rear or 35mm
Or same front size backs 18x9.75 20mm
Looking for a flush setup. Megan coil overs stock is250 brakes
Car is 2010 is250 awd and rolling diameter had to be close to same
Also tire thickness will be 35/40 as the roads in Chicago are extremely bad.
Xxr 527
#342
Hey guys,
Dimensions:
Thanks!
Dimensions:
Thanks!
225/40/18 and 255/35/18 have a few mm difference. those will be fine for the AWD system. I run the G-Spider 18s with 245/40/18 all around without rubbing so this setup shouldnt rub at stock height.
Tire Calc....
http://www.tacomaworld.com/forum/tir...0r18-255-35r18
#344
So, I just received my Varrstoen wheels.
18x9.5 +12
18x10.5 +15
I have a AWD, but I want to run stretched tires and I'm on coils, what tires are recommended? If you guys could help me! Thanks !
18x9.5 +12
18x10.5 +15
#345
I wanna run 19x9.5 +22 all around what tires should I go with and will I have any rubbing issue. Other then that if I go staggered 19x9.5+22 front and 19x11+22 rear the tire size will help, I'll be lower on road magnet springs. Thanks!
