Will those Wheels Fit an IS250 AWD - Part Uno
#77
Hi everyone, I'm new to this forum and a new IS250 awd owner so please take it easy on me. Currently running 17" stock wheels and tires. Would like to know if 2011 IS350 stock wheels and tires will fit my car. Wheels on the IS350 is 18x8 and 18x8.5. The tires are 225/40 and 255/40.
Wondering if running these would mess up the AWD system. Any help would be much appreciated. Thanks!
Factory Set-UP
is250 AWD ---------------is350 Rwd staggered
Front 225/45R17-----------Front 225/40R18
Rear 225/45R17-----------Rear 255/40R18
#79
I plan on getting some 20"X8.5 with offset 38 wheels on my IS250 awd and wanted to know if these tires will fit on these rims: 235/35/20?
I plan on adding coilovers later to lower the car.
#80
Does anyone have any pictures of 20s on their awd 250 without having it lowered? I would like what it would look like with these rims
http://www.carid.com/panther-wheels/spyder-273815.html
Thanks guys
Thanks guys
#83
I have been reading, but could not find infor on following specs:
Bolt pattern : 5 x 114.3
Size : 19 x 8.5 (F) & 19 x 9.5 (R)
Offset : 38mm (F) & 45mm (R)
Hub Size : 60.2mm
Will this work? What size tires to ensure no messing up AWD system? Thanks for any help.
Hub Size : 60.2mm
#85
Thanks Sleekbrian. If you do it soon and have pics would love to see them. Also are you lowering yours? Any modifications needed to run these, im thinking not, but if you know otherwise.
#86
heres some pics before the drop. totally monster trucking.
After the drop
1.25 was perfect for me. This is my only car and I like being able to get around without scraping or rubbing.
more pics can be seen here http://public.fotki.com/remydee/the-is-journal
#87
Diameter: 19 inches
Width: 8.5J Front
10J Rear
Offsets: ET 35 front / ET 43 rear
Bolt pattern: 5x114.3
Centerbore: 73.1/67.1 (hub centric rings are included)
What tires should i run with this?
I know the fronts i can do 235/35/19 and itll only be 0.20% slower, but can you help me with the rear? Im not sure how the whole stretching tires thing works
Width: 8.5J Front
10J Rear
#90
I've picked up a set of staggered IS350 wheels but I want all the wheels to be the same size for my AWD so I'll have to pick up a pair of either 8.5" or 8" which leads me to my question.... I'm wondering if I can run the 8.5 width rears all around or should I run 8" all around? .
Another questions is any of you members have issues with AWD binding at full lock with larger or staggered wheels?
Thanks!
Thanks!
