IS350 cig lighter/12v port not working?
New to the forum here! I own a 2007 IS 350. Both cig and other plugin went out. Thanks to a quick Google search, I found this thread and it worked! I took a couple pictures for reference to help out the next person in need. Note: buy the low profile fuses with short teeth. I bought standard ones and my fuse panel won't go back on. I'll make it right soon. Can't stand that it's not on
Lisa
Lisa
The following 3 users liked this post by LISAF3R:
Fuse Fix!
It's a easy fix guys. Check under your passenger side. The middle column will have two 15a fuse. One is your cigarettes outlet and the other will be your power outlet which is the one in your center console. Hope this help you guys out.
Same thing happened to me as well, i had to go to an audio shop for them to replace the fuse, cost about 20 bucks, but if i would have been on this board back when it happened i could have saved my money.
