View Poll Results: What looks better?
ISF tails
74
51.75%
2011 tails
69
48.25%
Voters: 143. You may not vote on this poll
ISF tails VS 2011 tails?
Old 11-19-12, 07:15 AM
  #76
scorpionge
scorpionge's Avatar
At least I CAME ACROSS the issue that the PLUGS on the INNER [TRUNK] plugs/socket is slightly different,
dont know If I need to cut the socket or change harness?
Old 11-19-12, 08:36 AM
  #77
brociouz
brociouz's Avatar
Originally Posted by jdm_altzza
^^^ if you say so... i know for a fact i do not have a 2009 trunk. thank you all for your pictures and information.
I believe you. Some pre-2009 trunks do NOT have the tab. My buddy with a 2008 IS for instance was able to install his 2011+ tails no problem.
You're suppose to change the entire harness. You reach behind the sheet metal and squeeze the white plastic clip that pops into the trunk, then after that's free squeeze to get the harness separated.
Old 11-19-12, 10:48 AM
  #78
Gearbangin
Gearbangin's Avatar
I got the F tails and might switch out.
Old 11-19-12, 06:51 PM
  #79
scorpionge
scorpionge's Avatar
I understand that but its just that the stock 2008 harness from the car TO THE INNER TAIL LIGHT is different.. it doesnt seem to fit the new 2012 Tail light assembly.. let me see if I can get it out and take a good pic..
Old 11-19-12, 08:16 PM
  #80
brociouz
brociouz's Avatar
Yeah, that's what I mean by the harness. You replace the whole wire harness that goes to the inner tail light (same for the outer tail lights too as I recall).
Old 11-20-12, 10:23 AM
  #81
tziegler03
tziegler03's Avatar
I have a new 2012 and love my tail lights!
Old 11-20-12, 10:13 PM
  #82
scorpionge
scorpionge's Avatar
Is there any DIY that you recall..
I was searching the forums and couldnt find anything on it..
I thought it was plug n play until they got here -=S
Old 11-21-12, 08:09 AM
  #83
brociouz
brociouz's Avatar
It looks like you already found the DIY I wrote: https://www.clublexus.com/forums/is-...tallation.html
It is all plug and play. If you're still having trouble post pictures of where you're stuck and I'll try to help.
CalitriSC
07-21-13 08:30 PM
infate
15
10-18-12 10:47 AM
infate
06-11-12 06:00 PM
Denver
08-04-11 08:41 AM
PurduePete
IS F (2008-2014)
14
04-03-11 02:44 PM
Quick Reply: ISF tails VS 2011 tails?
