Fogged up Passanger Head light
So i got my car 2 months back from the dealer
and lately my driver side head light keeps getting fogged up
and its only that side
i have spoken to 4 other is250awd owners in my area and everyone has the same issue
any one else experiencing this
or what could be the issue?
Thank you
Thank you
I had this problem in both headlights when I installed a HID kit, all I did was silicone the notches I cut in the back housing cover and parked the car in the sun for a few days. Eventually the moisture will dry out so give it some time.
But another question, how bad is it fogged up? Since "fogged up" is subjective to many others.
Did you change your headlight bulb or any mods to the headlight?
There has to be a reason when moisture was able to get into the headlight house. You can try to tighten the headlight bulb to make sure the seal is good.
If the moisture build up is bad, you can throw in a pack of silica (that moisture absorbing thing found in chips , purses , shoes , etc).
