Pothole misaligned my headlights
Old 08-28-10, 10:44 AM
Hayk
Hayk's Avatar
Default Pothole misaligned my headlights
Hit a big pothole on FDR Drive going south in NYC. I had the headlights on at the time. Only noticed the problem when I was driving back at night. I hit it with my passenger side, so the right headlight is pointing very high, while the left one seems to be normal. Do you think adjusting the vertical screw is a good idea or could something else have caused it?
I wanna fix it myself since I heard and read about how easy it is. But then I'm a bit worried that it's not just a normal adjustment that needs to be done, so the dealer is my best bet.
Luckily nothing else got damaged. Sometimes those 17's are life savers.
Old 08-28-10, 10:49 AM
mikez
mikez's Avatar
The dealer should fix that for free, I brought my car to the dealer complaining that my headlights were too low and they adjusted and measured it and told me it was factory spec.
Just tell them you dont think your headlight is factory spec so you cant see.
Old 08-28-10, 12:02 PM
LiCelsior
Retired
LiCelsior's Avatar
lol nyc roads ftl.
Old 08-28-10, 01:43 PM
SPNinjA
SPNinjA's Avatar
x2...
Old 08-28-10, 01:59 PM
Koz
Koz's Avatar
Had to adjust mine at least a half dozen times.
Koz
Old 08-28-10, 02:55 PM
ton3r
ton3r's Avatar
dealer fixes this for free?! i hit a tire on the freeway and now my passenger headlight is also shooting upwards
Old 08-29-10, 12:56 AM
allst4r
allst4r's Avatar
this happen to me aswell
Old 08-29-10, 12:28 PM
guacamole
guacamole's Avatar
i have this problem aswell.
suxx.
Old 08-30-10, 07:03 AM
vdubturbo
vdubturbo's Avatar
Had exactly the same problem... my issue is after they adjusted it to "spec" they still appear too low. Still battling with the dealer to try and resolve it.
My dealer sucks though.
Old 08-30-10, 07:59 AM
tex2670
tex2670's Avatar
my dealer downloaded info from the ECU which said there was an impact, and no warranty coverage. You should ask the dealer, and hope for the best.
Old 08-30-10, 08:37 AM
516IS
516IS's Avatar
Roads in NYC are no Joke... Glad everything else in your car is fine. Good luck with dealer.
Old 08-30-10, 09:40 AM
Hayk
Hayk's Avatar
damn, I didn't know they could do that. It's worth a shot anyway.
Old 08-30-10, 10:06 AM
AtlantaGuy
AtlantaGuy's Avatar
Bunch of BS. There is no impact sensor that detects whether or not you hit a pothole or had a had jar to the car.
Old 08-30-10, 02:13 PM
tex2670
tex2670's Avatar
true, true. mine was bumper impact
Old 08-30-10, 05:05 PM
VikH
VikH's Avatar
I fix mine at least once a month. Although, I have found that if I adjust them higher, they won't get misaligned as easily.
Quick Reply: Pothole misaligned my headlights
