TPMS issues with replacing rims
I have a 2006 IS250 AWD and im shopping for rims. i think i settled on the bremmer kraft br05's but they only come in 18's....dissapointing. I went to check out at tire rack and it said to get the tpms thing done it was like $360...obviously im not the most mechanically inclined. do i need to get this done to not have the light blinking and audio warning going off? or should i just order the rims and tires and take them to lexus to have it done?
First, not sure if Tire Rack gives you all the proper information so when you go to Lexus dealer, they can program a second set of TPMS (My IS250 can store 2 sets of TPMS).
If they do not, the dealer will have to un-mount your tires to get the information off the TPMS's. ($$$$)
What I plan to do is buy a set of TPMS of ebay for $55 for all 4 and make a Pipe Bomb (just do a search on here and you will find out what it is). Cheap and easy and no warning lights
Wrong they don't unmount your tire the scanner tool they have go next to your tire and read the tpms and give each part number. So buy a used set off eBay for like 60 and either Lexus or a tire shop with the tool can do it. Dealer will charge 100 and local shop maybe 30
What the dealer left out is that there's a tool that'll read that off the sensors without needing to dismount it from the wheel.
I suppose it's possible the dealer was unaware of this tool though, there's a lot of things dealers seem unaware of.
just take your stocks out, write down the #'s (just in case) and reinstall them in the new wheels/tires. Or get your new set from tire rack and go to a tire shop, and have them pop in the sidewall. You can get them in without completely dismounting the tire and you also will not need to rebalance.
