Proper way to operate CD player?
What is the proper way to insert CDs, eject, and switch CDs in the 6 disc changer. Do you insert 1 CD at time and wait for the flashing light to stop, then press the button again to insert another? Also what about changing from CD to CD? Do you just abruptly stop a current cd you are listing to by pressing another cd selection? I want do it correctly so I can extend the life of my unit as long as possible
Read the instruction Manuel?
Yes you insert one cd at a time, don't insert 5 cd at once because it would jam.
To change to another cd, just select the next cd. No need to stop the current playlist. Just use common sense.
![Post](https://www.clublexus.com/forums/images/icons/icon1.gif)
^ its in the manual.
but yeah, the two lights on the edges of the insert slot will turn red and green letting you know when it's safe to insert a disk and not. one cd at a time. and when shuffling between discs you can just press the type disc button arrow up or down since there isn't really a "stop" button..
tataysc300
06-21-11 09:39 AM
