Question about HID Fog Lights
Guys, I just bought the kit from ddm tuning.. And earlier, quang gave me the link for DIY to install the hid but the problem is, there aren't any wiring harnesses used in the Walkthrough. therefore, I was just wondering if someone have another DIY Walkthrough that contains how to install the harnesses.
Thx a lot
Thx a lot
Thx a lot
Thx a lot
Sure, can u give me the photos? thanks though. I'm so sorry to make u guys write a lot because i have so limited experience in doing such things...
Btw, how can I also get the bumper off? And Do I need to use the car jack?
i just remember, you dont need a wire harness
just looked at my installation and notice that there wasn't a wire harness. it's just a plug and play setup.
no you dont need to jack up your car to take off your bumper, you just need to take off a bunch of screws.
I'm currently using a xtreme xenon depot ballast for my fogs and i haven't had any problem yet, before that i was using an after market ballast and i rarely have any problems, they mostly occur during the winter.
Former Sponsor
You should disconnect the negative terminal from the battery in order to avoid electric shock.
8000k will provide intense blue color output but it will not be as functional as a 4300k or 5000k. Higher color tempertaure HID kits are rated at less lumens than lower color temperature kits.
VAlexIS250
09-19-14 11:15 AM
