How do I change the HID bulb in my IS350?
Trying to find some info on "how to" change the HID bulb in my car. No info in the owner's manual on this. Is this something I can do on my own? Already purchased the HID light bulbs...much cheaper than what the dealership wanted. This is my first time on forum, hoping to find some help. Thanks!
First you have to use a little screwdriver or something to pull up the center of the push pins so you can pull those out to remove the panels. Then on the back of the headlamp assy there should be the bulbs. Haven't done it on this car, so don't know what setup they have. Usually a connector must be pulled, a lock of some sort twists off, a spring may hold the bulb. I will look at mine later and see if I can take some pics of what must be done.
I changed mine to 6K this weekend with a help of this DIY https://www.clublexus.com/forums/is-...hid-bulbs.html
Last edited by supra06; 09-20-10 at 11:21 AM. Reason: Took about 20 mins. and simple
Couldn't have done it better myself!
cvuplay
RX - 3rd Gen (2010-2015)
09-19-22 01:10 PM
