GFX kit and lip spolier
It depends on YOUR skill level. If you are a total newbie to body work, it's going to take you a long time. Conversely, if you have some experience, then it'll be quicker.
I never installed any kits, but I figure that it's going to take some drilling and 3m taping... and alot of patience to get the alignment. It's basically remove and replace.
I have never done lip kits before but it was pretty straight forward, just follow the instructions. The rear took long bc there was drilling and cutting involved.
Front, - jack up car, replace stock lip with gfx using the same screw. - 15 Minutes
Rear is taped on over stock rear is 3M tape only (use extra tape), no, drilling needed, this thing isn't going anywhere. - 15 Minutes
Sides - replace original skirt - 5 min.
I tape mine on and so has many people, and it's holding up very strong.
Note: Add extra 3M tape, clean surface with rubbing alcohol before applying. Probably should get two people to center the spoiler on the trunk.
Great write up just posted today on the skirts:
https://www.clublexus.com/forums/is-...t-removal.html
circuitt
CL of Southern California
03-19-13 02:16 AM
