New IS350 MPG rating increase
Old 09-23-10, 07:55 AM
kennymacks
kennymacks's Avatar
Where did you hear this? The 2GR-FSE has always had port and direct injectors. This is true since 2006.
http://www.sae.org/automag/techbrief...1-114-1-17.pdf
Where do people come up with these blatant deceptions?
Lobux, I recognize that you are a well respected member of this forum, but please don't accuse me of blatantly deceiving people. I read about the efficiency of having secondary port injection on the 2011 and thought it was a new feature.
I stand corrected about the port injection being new, OK? I hope I haven't caused too much damage to this forum by trying to contribute and making a mistake. I think I'll just remain a reader instead of a writer.
Old 09-26-10, 01:36 PM
darrelld
darrelld's Avatar
I noticed this bump in 2011 epa ratings as well. So far it seems no one knows for sure why the increase in ratings.
Judging by the amount of increase it could be the IS350 is getting Toyotas new
Valvematic technology promised in 2007.
http://www.toyota.co.jp/en/news/07/0612.html
http://www.youtube.com/watch?v=RHNXbGGvOdc
Old 09-26-10, 02:20 PM
soupdawg
soupdawg's Avatar
my window sticker thing says in small print under the mpg rating that most drivers will see 21-29 mpg range. when i go from southern to northern cali im usually getting 27-29 mpg the entire trip. i guess they found most people getting around 28 mpg and thus change the rating.
Old 09-26-10, 04:17 PM
Kurtz
Kurtz's Avatar
They can't just change it based on what "most people" say.
The number on the window is the result of testing done (by the car maker) according to EPA guidelines.
As I said earlier, they switched to thinner oil. That's almost certainly the reason the numbers went up.
Old 09-26-10, 06:32 PM
darrelld
darrelld's Avatar
According the Mobil, the most oil viscosity could improve fuel economy is 2%. The 2011 jumped by more than 10%. Could be a combination of the oil Viscosity and Valvematic to result in the improvements.
"*Based on 20 MPG, $3/gal gasoline and a potential 2% fuel economy improvement (based on a comparison versus those grades most commonly used). Actual savings are dependent upon vehicle/engine type, outside temperature, driving conditions and your current engine oil viscosity."
http://www.mobiloil.com/USA-English/...l_1_0W-20.aspx
Valvematic is supposed to also bump HP ratings by up to 10%, that would make the 3.5L around 330hp similar to the Infiniti G37. You would think at least the improved EPA rating would be worth a mention somewhere in the marketing material.
Old 09-26-10, 07:11 PM
Toymota
Toymota's Avatar
What about reprogramming the automatic shift points and the throttle mappings? Has anyone driven a 2011 to see?
Old 09-26-10, 08:36 PM
Kurtz
Kurtz's Avatar
The fact they've made no changes to the listed HP (but did to the listed MPG) suggests to me they didn't change anything at all about the engine.
Mobil 1 has a vested interest in not overstating what the lower viscosity oil can do...
While Lexus can self-report their EPA MPG test results and insure they get the most optimal result possible with the lower viscosity oil.
(and the fact that the "new" figures are now closer to both what the original IS350 mpg ratings were, and more in line with real world results, makes me think they just went conservative when they first re-rated with the new EPA test, and now they've figure out how to "optimize" the testing results, plus whatever the lighter oil gave em too).
Old 02-16-12, 06:19 PM
Leander311
Leander311's Avatar
Did anyone ever learn a more definite answer to this question? It would seem someone at Toyota/Lexus should know and would be proud to share why... Esp given the significant 10% change. The truck ads go on for days for a 5% change, so what gives here??
Old 02-16-12, 06:32 PM
kevhitch
kevhitch's Avatar
I have an 07 IS350 and I just pulled out the window sticker and it says the averages are 21 and 28. Maybe I'm missing something here...
stlgrym3
06-07-21 06:53 PM
garroids
04-11-14 12:44 PM
Shervin021
02-10-12 09:28 PM
LEX Fairy
02-03-11 07:07 PM
SilverBull
03-16-08 09:12 PM
Quick Reply: New IS350 MPG rating increase
