How low can you go on fuel tank?
Old 09-28-10, 02:19 PM
Sango
Sango's Avatar
Default How low can you go on fuel tank?
Hi,
Just curious, where exactly would be the critical point where you would need to fill up or the car would stop.
So far I'm trying to gauge how far I can go on a tank of gas on my IS250 AWD. So far I had gottne 396 miles, a wii short of my goal to hit 400 as the needle is right on the final line at E, with 0 approx on the range.
When the vehicle is off, the needle all the way the left passed E with a gap. The question is, the gap, can it be assumed that means there is still gas within the tank even thou it is passed the final line of E?
Thanks
Old 09-28-10, 02:28 PM
willi3ja
willi3ja's Avatar
A)There's only one way to find out
B)What's the big deal if you know can go another 5 miles without having to stop/Why bother cutting it that close
Old 09-28-10, 02:31 PM
windex
windex's Avatar
I drive until I cant see the tip of the E on the upper left corner.... but when I see that I know its time to get some ****ing gas!!!
Old 09-28-10, 02:32 PM
Sango
Sango's Avatar
I can answer B). If I am travelling and cannot find any gas stations along a route and trying to find a station. Of course, I should fill it up before then but lets assume worst case.
Comming from a 1999 Solara, I could get about 400 Miles on it as well, considering it is a 18 gallon tank. Hoping to pull it off with the IS, to see how much more fuel efficent it is compared to the previous vehicle I had travelling the same approximate distance.
Before that, I had a 1995 Corolla and managed to pull off 500 KM. Only did that one and never did that again since it was too risky, then just did back 400 KM on this vehicle.
Old 09-28-10, 02:40 PM
heyarms
heyarms's Avatar
I've only ran mine down to "1 mile approx." point. Gotten mid 400's on tanks of gas in my 250 tho
Soon to be switching to a corvette, cant say ill miss the gas mileage
Old 09-28-10, 02:43 PM
Lexitegra
Lexitegra's Avatar
I found people discussing that here as well:
http://my.is/forums/f87/is250-tank-c...isplay-312802/
People seem to think there's about 2 gallons left or a 10% reserve. I myself have never tested this and don't really intend to but if you do, let us know how much further you were able to travel!
Old 09-28-10, 02:44 PM
Sytfu_IS
Sytfu_IS's Avatar
Once it hit 0, I believe I drove about 30miles more before my car ran out of gas and died.
Old 09-28-10, 02:48 PM
kumquatism
kumquatism's Avatar
^This sounds about right. I've driven around for a good 20~ miles before with the 0 on estimation. It didn't die on me. So I'm guessing it can take a little bit more than 20.
Old 09-28-10, 02:49 PM
Sango
Sango's Avatar
awwwwww! Did you have a spare tank of gas in the trunk or you have to get it towed!??
On the side, if you let the car die from letting it get to empty, I heard that is not good for the car. True?
Old 09-28-10, 02:51 PM
Sytfu_IS
Sytfu_IS's Avatar
Originally Posted by Sango
awwwwww! :=( Did you have a spare tank of gas in the trunk or you have to get it towed!??
Oh luckily it was when I was while I was warming up the car. I drove 20-30miles then went home and was planning to pump the next day. Gas station only 2miles away so I figured I'd last there but I guess I drove more then what I really had left since it doesn't show how much gas left you have to drive.
Old 09-28-10, 04:08 PM
KWang
KWang's Avatar
^ haha . you never know how far you can go until you try right !
personally .. i think i went about 15 miles in the city before i went to get gas.. i was on the way home and i pretty much live half a block away from gas station =D
Old 09-28-10, 04:37 PM
Raralith
Raralith's Avatar
Damn, and I was worried when it said 7 approx miles for me. Good to know about the ~30 miles more.
Old 09-28-10, 04:42 PM
syzygy
syzygy's Avatar
30 miles more on an IS350 sounds about right.
I've done this experiment countless times on my IS350, and the results are extremely consistent.
When I run my car down to 0 miles, I always end up filling up the gas tank to (fuel capacity - 2 gallons).
The fuel tank capacity in the IS350 is 17.1 gallons. At "range = 0 miles," I always fill up to 15.1 gallons (it varies ever so slightly from 15.08x to 15.09x).
This means that there's a reserve of 2 gallons of gas after the range hits "0 miles."
At approximately 20 miles per gallon, theoretically you could go an extra 40 miles but that would be madness. I'd imagine you could safely go 20 to 25 miles.
Old 09-28-10, 04:44 PM
kuuqi
kuuqi's Avatar
You can safely go another 20-25 miles if you wanted to. I wouldn't recommend it as the fuel pump likes to have, well fuel! lol. I've gone maybe 15-20 miles max after the 0 with no problems.
Old 09-28-10, 04:45 PM
syzygy
syzygy's Avatar
By the way, the results have been so consistently close to "2 gallons" (1.995 gallons, 1.992 gallons, so on and so forth) that it leads me to believe that this is by design. Lexus wanted the car to have 2 gallons in reserve after the range hit 0.
This applies to IS350s.
Quick Reply: How low can you go on fuel tank?
