Product Warning Nokya Hyper-yellow Fog Bulbs
Old 10-06-10, 12:01 AM
  #31
iSuxeL
iSuxeL's Avatar
Get the harness, it's easy PNP. It's like changing a fuse and putting a higher wattage one, would you do that?
Old 10-06-10, 12:44 AM
  #32
llamaboiz
llamaboiz's Avatar
you know why ppl are having problems, they running too low/too aggressive offsets/making holes in their liners and not doing anything to patch that hole up... drive in the rain and moisture gets in~ BAM messed up fogs and of course blame the bulbs...
Old 10-06-10, 01:14 AM
  #33
Oreo27g
Oreo27g's Avatar
SAME THING HAPPENED TO ME! HAH! I'm so done with my car though, I don't even care anymore... But I remember looking at it and then sure enough my other one is out... It's whatever now, I'm scrapping my IS350. Too many little problems, but probably didn't help that I didn't stick with OEM, lol.
Old 10-06-10, 04:15 AM
  #34
IXI187IXI
IXI187IXI's Avatar
Originally Posted by EyeKutr
Aaaalllllright then..... these 9006 bulbs state something like 70W output at 55W power.....so as to imply more output than power. I would NEVER put in bulbs with a higher wattage than OEM. Buyer beware, Here is the pic of the packaging on my bulbs NOTE STOCK WATTAGE
here is some text from ebay
NOKYA PN NOK7610 TWO (2) NOKYA BULBS
Product Description
The Nokya Hype Yellow bulbs are a line of high performance light bulbs. Eurostyle yellow light with a HID appearance at 2500 kelvin. For poor weather conditions yellow reduces light glare at night. These are stock output halogen headlight bulbs. Improves your driving at night during poor weather.
Product Specification
Bulb Type 9006 (HB4)
Wattage 55 Watts - 2500K
Pro Halogen Technology
im not trying to be a **** but i still dont see the problem. these people that list crap on ebay dont know anything. im sure thats some generic subject they ripped off another item. the box clearly says 70 watts. thats the problem right there.
Old 10-06-10, 10:20 AM
  #35
EyeKutr
EyeKutr's Avatar
@ IXI - it was not nice to say "dont post this, this is clearly user error".....look at the website for Nok7610- these are 55w bulbs ....I would not be dumb enough to put in higher wattage without taking precautions, when I had researched them I noted them to be the proper wattage. I even called them up today (they are local to me btw) and they told me, yes they are 55w bulbs with a "70w" looking output - marketing....they will research this and get back to me, whatever. I initially posted this as many of us get these and perhaps people should either get a harness or get a different brand or whatever.
Here is the nokya website so you can CLEARLY see you are wrong
BTW - my bulbs are stamped 55W
http://nokyausa.com/hy/hy.htm
Old 10-06-10, 01:28 PM
  #36
my95tsi
my95tsi's Avatar
It's not user error. I had these bulbs on my 2006 IS350 before i sold it for an 08 IS350. Needless to say the same thing happen to me, it took about 6 months but i noticed that the passenger side went out and not the drivers side. I pulled the fender well cover to find that it did the same thing and melted the harness. Do a search it's has happened to numerous people but only appears to be happening on the passenger side and not the drivers side. I bought the high heat Nokya harness and just replaced it on the passenger side and left the drivers side stock. I bought a new bulb and 6 months later it melted the upgraded harness while the drivers side was still intact. I replaced the harness again after that, this time on both sides and never had an issue after a year of use. I won't be putting these bulbs on my new IS350 but it is fairly common. Those who are saying that the wheels are rubbing the fender well causing water to come in don't know there @ss from a hole in the wall. You can spary the harness all you want with water and it won't make a difference they are sealed.
Old 10-06-10, 01:34 PM
  #37
my95tsi
my95tsi's Avatar
I should also mention that I called Nokya to complain once it melted their upgraded harness. They asked me to send pictures which i did. I never heard back from them, I called spoke to someone who said they'd call me back and they never did. Needless to say I wouldn't recommend these bulbs to anyone they are cheap and their customer service sucks. I've used these bulbs in other cars without a problems and i've also used them in other cars with these same problems. I wouldn't risk it with such a nice car, it'd be worried they can fry the whole wiring harness which is something you don't want. Either stay stock or go with HID's.
Old 10-06-10, 09:49 PM
  #38
soulsoarer
soulsoarer's Avatar
My Nokya package says 55w on the sticker, of course also stated on the bulb. There must be different versiosn of it because I see pictures with 70w and 80w on the package sticker.
Old 10-06-10, 10:01 PM
  #39
llamaboiz
llamaboiz's Avatar
so... if nokya is so horrible, why has mine lasted 3+yrs with no harness damage, of the many members here i've installed this bulb in their cars, only 2 have come back due to a bad bulb and no harness damage when i swapped in a new set...
so what?
Old 10-07-10, 02:20 AM
  #40
blkis_250
blkis_250's Avatar
judd both my harnesses look like that.. idk what happened either, i bought ones that were rated at 55W and they've all burned out...and melted my harness...would you happen to know how much a new harness would cost?
and if it get HIDs, will that replace the two melted harnesses? or will i be working off of my stock harnesses?
Old 10-07-10, 09:28 AM
  #41
Synetix250
Synetix250's Avatar
Question
Originally Posted by CLIS250
LUMINICS:
also have PIAA City Light bulbs, right behind the DRL, but i dont happen to have a picture of that. I also went safe with the Luminics instead of the Nokyas, just paid a little bit more.
Hey CLIS250, what kind of fog lights do you have? Aftermarket halogen or hid? Thanks.
Old 10-08-10, 11:29 AM
  #42
blkis_250
blkis_250's Avatar
can someone answer my question up there? post #40...
Old 10-08-10, 08:24 PM
  #43
CLIS250
CLIS250's Avatar
Originally Posted by SilentWish
thank you so much man!
i guess yellow DRLs are the only ones that can differ from the stock yellow
all other coolors (white, blue, purple) all end up being stock yellow at 30% power
are these the ones u got?
the link giants posted above
http://www.luminicsbulbs.com/jdm_yellow.php
if so i'm buying!
yes those are the one i have, you might try around on ebay they run alot cheaper.
Old 10-08-10, 08:26 PM
  #44
CLIS250
CLIS250's Avatar
HID 6K. I don't think that color can be achieved by halogens. LOL.
Old 10-08-10, 10:51 PM
  #45
SilentWish
SilentWish's Avatar
thanks man!
let me do some searching
shahir18
Lighting
38
10-27-16 08:11 AM
Jay hall
04-20-12 03:32 PM
EyeKutr
10-06-10 11:56 AM
weesped
12-30-07 10:14 PM
whitcobra
Lighting
05-12-04 10:11 AM
Quick Reply: Product Warning Nokya Hyper-yellow Fog Bulbs
