Stock tires screeching?
Old 10-05-10, 10:41 AM
flektone
flektone's Avatar
Default Stock tires screeching?
Anyone else notice the stock 17" tires screech even when filled with the proper pressure? I only notice it when pulling into a parking lot slow and turning into a parking spot. I was off a couple PSI's and went to fill the tires. It happened right after I put the correct pressure in as well.
Old 10-05-10, 10:44 AM
aarongue6
aarongue6's Avatar
Maybe the ground is flat and slightly polished instead of rough. So it's screeching because it's turning on a slippery surface.
mikez
mikez's Avatar
like your rubber sole shoes squeaking on a hardwood floor?
that is a property of materials man, independent of air pressure.
Old 10-05-10, 10:49 AM
Pnthrzrule
Pnthrzrule's Avatar
I wouldn't worry about screeching as you are making sharp turns or parking...it's a combo effect derived from having an AWD (i'm assuming yours is all wheel drive) and the surface. Now...if you find it screeching while entering/exiting a cloverleaf (at normal speeds) then that most likely means your tread depth is getting low and it's time to start saving up for new rubber. I hope this helps!
Old 10-05-10, 11:02 AM
flektone
flektone's Avatar
ok thanks for the input guys
uchujin
12-19-18 10:51 AM
Sin1UZFE
10-01-18 07:16 AM
siffe
01-08-10 11:53 AM
guysfo
05-31-07 06:21 AM
kloh7
01-31-07 01:47 PM
Quick Reply: Stock tires screeching?
