AFS OFF Light...I SEARCHED! Still on...
Sooo...my lights been on for a while. I have searched high and low on these and other forums for the fix. All sensor arms are set proper. All connections seem good to go. Drivers side functions, passengers does not and is super low compared to my drivers side.
Could my vertical adjustment being to high or to low effect the AFS functioning properly?
Recent body work had my passengers headlight getting replaced...this is my biggest concern now. Is there a way to tell if the headlight is equipped with AFS? I know my car has it. And my old now cracked headlight worked JUST FINE prior to replacement, and AFTER the hit it took to crack the housing/tabs...but now Im thinking there's a chance that the new headlight that was ordered...wasnt the right one...Fu*k me.
Any help would be super...
thanks~
thanks~
AFS OFF is flashing constantly...My toggle on the dash display is dimmed out, I can't select it have it on or off.
Pretty sure I have an AFS equipped unit as the ASF motor looks to be onboard.
Would the dealer need to tap into my ecu and tell it anything to reset or something...can they do that...Id assume it has tossed a code of some kind. Might that code enlighten what part of the headlight is causing the lack of function?
Killin me...
Killin me...
mikegs2006
10-13-11 05:50 PM
