Smokyis350 1/4 mile runs
#31
Things have gotten cooler around these parts. I was driving around (dry conditions) with traction control off a few hours ago. From around 40, I punch it and get...wheel spin in 2nd gear. I almost lost control - thank goodness this didn't cause some sort of accident.
I was shocked that even in dry conditions I could not get enough grip to safely accelerate through 2nd gear with traction control off while going 40 MPH. Seems like the cooler weather appears to have a serious effect on traction.
It has more to do with how worthless summer performance tires get in cold weather.
#33
I think snow tires might be somewhat overkill down south when we average approximately one snow day every 10 years
![Cool](https://www.clublexus.com/forums/images/smilies/cool.gif)
#34
For improving E/T times, R/T does nothing. You can fall asleep at the wheel, but as long as you don't cross the beams, the timer doesn't start; you will lose the heads up though. That being said, you should be aiming for better R/T as it is an essential part of the overall essence of drag racing, i.e., the human component of the situation.
#35
I have already installed the intake for the last runs. Next Wednesday will be in the 60s so I will see how I do then.
Yes, I lowered my PSI just a little bit. It is running better. But it seem like the track is better prepared than last time I went.
The 19's definitely killed my times. Maybe some lightweight wheels with DR will improve my 1/4 by .1 or .2.
Even with my crappy R/T, i only lost 1x.
#36
A little as in still in the 30 PSI range? I ran with that for quite a bit, but once I lowered it to 24 PSI, I didn't have any problems with that.
#37
I have my front tires at 40 PSI but will give it a shot with 50 PSI and see if that makes any difference.
Still trying to find the best RPM to launch the car. I have been launching at around 1100 RPM without traction problem but will try next time at 1300 RPM.
#38
Got back from the track. Broke my best record.
13.1@104.4. It was around 55 to 60 degrees. Was hoping it would get colder. I had a 30 minute break on that run and was first to go.
There were too much FWD using the wet box leaving water all over the track. I lost traction 2x and was spinning from the beginning to half way. I decided to just let off and slow down. Ran a 23 second run.
All my other runs were pretty consistent when there weren't FWD using the wet box in front of me. I've ran mostly 13.3@103 3x.
![](http://i24.photobucket.com/albums/c40/itzvictor/28fbd474.jpg)
![](http://i24.photobucket.com/albums/c40/itzvictor/750aadc5.jpg)
![](http://i24.photobucket.com/albums/c40/itzvictor/0f4e324f.jpg)
I was .02 from running a 13.0.. Hoping to at least get in the 12s when it gets even cooler in 2 weeks when the season ends. I am pretty confident I can get into high 12s with cooler weather.
#39
Time slips are up:
http://www.dragtimes.com/Lexus-IS350...lip-21998.html
Might go one more time before season ends. Will keep you guys posted.
#40
32 PSI. I haven't have any problem with traction. I will give that a try next week for my last few runs with 25 PSI.
As for launching the car, I really don't think RPM launching on street tires does much. I've noticed when you go WOT, you don't move right away, rather the RPM's jump to around 1.5k and than you feel yourself start to move. RPM launching didn't seem to make a difference to me as it still took that 1/10 second for the power to get to the wheels anyways. Slicks are different because you can launch at 2.5k+ RPM and not have traction problems whereas if you did them with streets, your tires wouldn't hook.
#41
You know if you got a perfect launch (1.91 60' time like toothdoc got below), that would knock off MORE than just .1 off your 1/4 mile since you're picking up that .1 second early on. You could actually conceivably get into high 12s (12.9x) which is something I always figured possible but just didn't happen because most people don't drag their IS350s.
Good luck man. The ISF is already an 11 second car (all motor) thanks to cayman. Let's see if we can make the IS350 a 12 second car (motor). Obviously with N2O it's easy to get into the 12s. I know somebody gets low to mid 12s on N2O with their IS350 (times aren't posted on dragtimes, though).
#42
I've still been having a hard time doing a burn out. Many people been coming up to me asking if I have nitrous because I can't do a burnout but when I launch like nothing.
I do have the pedal recall. I place my foot on the brakes and accelerator at the same time and I place constant pressure on the brakes while I bring my RPM up. I then slowly let go of the brakes but it just slides a little bit.
Yeah, I wish I can get into the 1.9s but I have 19 inch wheels on right now. When I modded my car I never expected to bring to the drag strip. Just for show and random street racing.
Cayman is just crazy. I don't know how he does it. IS350 with 12.8 @ 109. That is some crucial trap speed. Definitely props to him for setting a record for the IS350 and IS-F.
IS350 is definitely a 12 second car with bolts on. (PPE headers 16 WHP, full exhaust, intake) I think if I had some light weight 17s I could of made it into the high 12s that night with ~60 degrees.
It is just good to show other people that underestimate what the IS350 is capable of. There are all these muscle guys that can't believe that my car is beating their mustangs with just intake and exhaust. 335 owners are in disbelief thinking that I have nitrous in my car.
#43
Congrats. I only have an 1/8th mile track around here. I went a couple of weeks ago and after driving 30 miles to get there, I drove right into the staging lanes.
I only spun the tires a little to clean them, stayed out of the water, left traction control on and ran:
1.9783 sixty foot
8.6553 1/8 mile time
83.18 mph
The next pass was an 8.7xx and then I took off traction control, put it in sport mode, and the car just spun too much the next two passes.
The car has zero mods and I think 8.6xx is very respectable for a 6 cylinder. The only chnge that tempts me is to put some drag radials on it for better sixty foots.
1.9783 sixty foot
83.18 mph
#44
#45
1.9783 sixty foot
83.18 mph
1.9783 sixty foot
83.18 mph
What PSI are you running? I lowered my PSI from 40 to ~30 PSI on my rear and turned off traction control and have no problems launching now. My 13.1 run is with traction off. The first time I went my car was running 40 PSI and I just spinning my wheels.
You might want to consider getting a intake or exhaust.
