instrumental panel tachometer and speedometer needle noise
![Unhappy](https://www.clublexus.com/forums/images/icons/icon9.gif)
Hey guys.. i need your advice.. please help...![Sad](https://www.clublexus.com/forums/images/smilies/sad.gif)
ok.. yday i took my car for 35k service and all was good until when i sat in the car to start and i noticed a weird sound..
The first time wen u push the ignition .. its on and the second time wen u push it.. the lights of the instrumental panel are on.. and the needles of both the tachometer and speedometer goes frm left to right and back ..
bt i noticed yday.. that wen it did dat.. the needles made a noise as if it was scratching the panel and they were a bit slower than they used to do..
Is this normal or am i going crazy ?
and if there is a problem .. how can i solve it?
thnks in advice for you feedback...
http://l.yimg.com/dv/izp/lexus_is_25...entcluster.jpg
When I got my IS, I noticed the dash sounds like a damn cash register when you hit the Engine ON and OFF button. It's not a huge deal to me, but I always wondered if it was normal until I got into a loaner for a few days(2010) and it did the exact same noise...
Edit; mine does not have electronic steering wheel adjust...just the normal lever underneath to adjust.
I dont recall my car or the loaners I have driven doing that.. Ill check that out this afternoon..
I just ran out side to check this because I was too curious..
Like I thought mines 100% silent on my 2008.. only difference i can think of, I have a electronic adjusting steering wheel that tilts itself up and down when you start the car.. so thats all you can hear on my car (tested a few times to make sure)..
And the 2 2010 loaners I drover were both standard features but were also silent on the instrument panel..
Love starting my car early in the morning (5:30am) with the radio off and hearing the motor purr as it starts up..
heya! Sorry for later reply... Had an Internet issue..now solved.. :-P
Ok I chkd with dealer and with other IS owners here and yup its normal to have that noise..I just didnt notice it b4.. Silly me. :-P
Also here in the middle east I also found that many IS owners complaining abt alignment trble..the car goes to the left or right when its supposed to go straight.
Where is Rashood; the all knowing IS guru :-P
Dude watchya doin in India?
Anyways y'all take care
And thanks for all ur feedbak.. :-)
trotondo
12-04-10 02:02 PM
2007, 250, car, cluster, instrument, is250, lexus, ml320, needle, noise, noises, rpm, speedometer, starting, tachometer
