XM Radio Install in IS250
Hello everyone!!
I'm new here and I need XM badly!! Is there anyone in the Chicagoland area that will help with the installation? I would like to order the parts online from Sewell, but I'm not as car savvy to do the install myself, much to my dismay
I know I don't want a separate antenna attached, and I heard that the shark fin antenna is utilized with the parts ordered from Sewell. Does anyone know of a place that will do the installation or has anyone done the installation themselves and would be willing to do the install for me? I'll pay for labor up to a reasonable amount.
Please! I'm going through XM withdrawal here!! Help!!
![Crying](https://www.clublexus.com/forums/images/smilies/Peace.gif)
Hello everyone!!
it's very simple, and it's totally plug and play. You basically just remove some panels in the trunk, plug everything into existing locations in the trunk, then put the panels back. No reason to pay anyone to install it.
(this assumes you have an 07 or newer... 06s don't have the sharkfin so they're outa luck on not using an external antenna)
I did mine and it was very easy, everything is located in the right rear of the trunk, its simple plug and play. I bought mine from Swell and it comes with instructions on how to install it and disassemble everything. Just make sure they send you the antenna that goes with the XM. I personally don't like the shark fin, so i took the XM antenna and just placed it on the top of my trunk, close to the third brake light and it works great, only time I lose reception is when I'm under a bridge.
Sorry, I should have been more clear..I have a 2007 IS250 with SAT radio capability and shark fin. I guess I just don't feel comfortable with the installation; knowing my luck, I might disconnect a major wire and ruin my car entirely ![Sad](https://www.clublexus.com/forums/images/smilies/sad.gif)
I'd pay someone to put the parts in, I've called a few car audio places near Chicago and they're quoting me $100 for labor. I guess in comparison to the dealer's quote, this is a pretty good deal?
+1 on the DIY
I thought i would mess up to when if first did it 2 years ago. Its really simple and easy. REmove all the trunk liner and at the bottom right there is an amp plug some wires in position the current hardware and your done. Put the liner back and enjoy your XM
Yeah... this is really a pretty easy mod. Unless you HE-MAN it, there's no way to plug the wires in wrong since they're all set up so they only plug into the correct spot.
I just did it Saturday... took me about 45 minutes. Hardest part is pulling all the lining out of the trunk.
HI there first off I wanna thank you for the opportunity for everyone to understand my ability to help out with this issue. Lexus Proud Owners! I just bought a is 250 2008 has a the XM OPTION. Turn Out that you also need the XM Kit for this to work. Some previous models don't come with a full XM KIT from the factory. This information was provided by my local lexus Dealer.
I know this is an old thread, but I just purchases a 07 IS250. I would like to install the factory SAT Tuner, but have not torn into the back yet, to see what all is there. So thought I would ask to see if you could tell me if the harness that is provided in the kit is necessary for the install. With the Shark Fin in place is the wires needed just vacant and need the tuner, or do I have to try and find a harness out of a wreck?
I think I have understood the harness is only in the kit and not just part of the factory wiring, but want to make sure I am not misunderstanding before I tear into all the panels in the trunk.
Thx
Thx
