Lowering 2010 AWD IS250
i'm curious to know why people are saying there are issues lowering the awd IS250.
on sewell F sport springs are going for around $260. Getting them installed by a shop isn't that expensive so i'm looking at around $360 installed.
the issue is, i've heard people say the reason why they got the rwd is cause they wanted the F sport package. why can't we get the F sport package on the awd?
is the F sport springs the best to lower the awd on?
or are there better recommendations for the awd?
thanks!
thanks!
F Sport is a good choice and your warranty will still be intact with them installed on your car because they are an authorized Lexus product. I met a guy a while back who had them on his AWD and he had over 36k on them and never had a problem, ran smooth. I say go for it!
i'm seriously considering it
but a friend at the lexus collision center said it has been said that F sport springs aren't recommended on the awd.. something about not being balanced?
didn't get more info tho
that's why i'm trying to do some research at a place where i'm sure a lot of people have tried different alternatives
![Cool](https://www.clublexus.com/forums/images/smilies/cool.gif)
a spring is a spring. there is no difference between an awd spring or a rwd spring with the exception of possibly the spring rates which isnt going to make a difference.
if you can get it installed for $100 bucks, that very cheap. you'll also need an alignment when its done too.
F Sport™ Equipment is warranted for 12 months from the date of installation or for the balance of the new-car or Certified Pre-Owned (CPO) warranty in force at the date of installation, whichever is greater, when installed by an authorized Lexus dealer. This warranty does not cover maintenance services such as replacement of brake pads/linings and clutch linings. This warranty does not cover noise, vibration, cosmetic conditions and other deterioration caused by normal wear and tear. F Sport Equipment installed by anyone other than an authorized Lexus dealer is warranted for 12 months from the date of purchase only, and the warranty coverage is limited to the replacement value of the F Sport Equipment. This warranty does not cover maintenance services such as replacement of brake pads/linings and clutch linings. This warranty does not cover noise, vibration, cosmetic conditions and other deterioration caused by normal wear and tear. Part failure caused by improper installation by anyone other than an authorized Lexus dealer may void the F Sport Equipment warranty, the new-vehicle warranty or both.
thanks for reading.
http://www.youtube.com/watch?v=yY9ReE-8c2E
This is the best awd suspension. lol I had springs, bcr coils, and now air on my awd. air is personally the best due to it being a closer to stock ride with any height you want at the click of a button.
thanks for all the feedback guys~
perhaps laobo979 is right about the unbalance
sorry about the lack of knowledge.. but why would coilovers be different from springs in the case of the awd? how would coilovers overcome the unbalanced issue?
PaPaHoFF! air suspension is crazy! i assume it's the most expensive out of all the suspensions available?![Cool](https://www.clublexus.com/forums/images/smilies/cool.gif)
are there any risks to it? as in.. electronic failures causing the air to release all of a sudden?![Stick Out Tongue](https://www.clublexus.com/forums/images/smilies/tongue.gif)
or since you can adjust the height at such ease.. will there be mechanical wear and tear quicker than springs and coils?
Coils can fix the unbalance issue by manually changing each corner's ride height. However I dont know if its an unbalance if it was designed that way by the OEM.
No idea about reliability of air, but I do know its common for the air pump to not work properly or a vale is broker and you don't have enough air to pump the car back up to driving ride height![Stick Out Tongue](https://www.clublexus.com/forums/images/smilies/tongue.gif)
Also, in cold weather, the air inside your compression tank condensing and freezing is a sure way to put your car out of commission if not knocking out your air ride for good.
