Flush look, fitment question? Need some advice!
i am currently running on work vsxx 20x9, 225/35 +36 front and 20x10 255/35 +32 rear. Im dropped on bcrs. i currently only have minor rub in the front on the tab and bolt that hold the bumper to the fender after i did some mods to it. my fenders are pulled and rolled/shaved?(removed the insulation on the inside). i am tucking a lil bit but i want to get a fuller flusher look so to speak, so i was wondering if i went a little wider on the tires 235/35 and 275/35 front and rear respectively, will that fill it out some(make it stick out a little more if you will) or will i need to use spacers? or will it just rub way too much?
I kinda got a responce from a member here to just run spacers and mod my fenders more but i wanted to post with some pics and see what others think. i dont really wanna mod my fenders anymore if possible :/
I know this is an art of its own and if i had the money to play around i would try different things until i get it to work but since im on a budget im trying to find out as much as i can and be able to do it right the first time!
![](http://i34.photobucket.com/albums/d106/d1mitrov/2010-10-16215602.jpg)
![](http://i34.photobucket.com/albums/d106/d1mitrov/2010-10-12142506.jpg)
![](http://i34.photobucket.com/albums/d106/d1mitrov/DSC00423.jpg)
![](http://i34.photobucket.com/albums/d106/d1mitrov/DSC00432.jpg)
![](http://i34.photobucket.com/albums/d106/d1mitrov/DSC00430.jpg)
![](http://i34.photobucket.com/albums/d106/d1mitrov/DSC00429.jpg)
![](http://i34.photobucket.com/albums/d106/d1mitrov/DSC00420.jpg)
![](http://i34.photobucket.com/albums/d106/d1mitrov/DSC00419.jpg)
![](http://i34.photobucket.com/albums/d106/d1mitrov/DSC00427.jpg)
![](http://i34.photobucket.com/albums/d106/d1mitrov/DSC00426.jpg)
![](http://i34.photobucket.com/albums/d106/d1mitrov/DSC00415.jpg)
![](http://i34.photobucket.com/albums/d106/d1mitrov/DSC00416.jpg)
I was thinking that like a 235/30 front and 275/30 rear? or should i stick with 225 and 255?
ok so i tried a 10mm spacer with my 255/35s but it would rub too much as expected. but this is what it looked like
![](http://i34.photobucket.com/albums/d106/d1mitrov/2010-12-08162025.jpg)
![](http://i34.photobucket.com/albums/d106/d1mitrov/2010-12-08162013.jpg)
![](http://i34.photobucket.com/albums/d106/d1mitrov/2010-12-08162007.jpg)
so i got a 245/30 tire with a 15mm spacer and it works but i need another degree or so of camber to cave the top in so it doesnt hit on bigger dips
![](http://i34.photobucket.com/albums/d106/d1mitrov/2010-12-24144838.jpg)
![](http://i34.photobucket.com/albums/d106/d1mitrov/2010-12-24144903.jpg)
![](http://i34.photobucket.com/albums/d106/d1mitrov/2010-12-24144909.jpg)
![](http://i34.photobucket.com/albums/d106/d1mitrov/2010-12-24144922.jpg)
![](http://i34.photobucket.com/albums/d106/d1mitrov/2010-12-24103922-1.jpg)
![](http://i34.photobucket.com/albums/d106/d1mitrov/2010-12-24103901.jpg)
![](http://i34.photobucket.com/albums/d106/d1mitrov/2010-12-24144828.jpg)
what do u think? to me it looks nice however...i really hate how skinny that tire is. my question is if i went with a 245/35 and a 10mm spacer and some more negative camber would it work?? also would it be weird if i left the front 225/30 or should i go like 215/35 in the front as well?
