225/40/18 tire size all around on stock is350 wheels?
i have an AWD is250 but i wanted to put the 350 rims on my car, to keep rolling diameter as close as possible i want to run the same tire size all around, one thing i am worried about is that the tire will be too stretched or is it ok to run the rears with 225/40/18s? any input would be appreciated
Just do 245/40/18's all around , you'll have less gap. Or I'd run something like a 255/40/18 in the rear and a 225/45/18 in the front. Check to see which staggered width setup has the same rolling diameters.
OEM IS350 setup is 225/40/18 front and 255/40/18 in the rear. Front wheel is 18x8 and rear wheel is 18x8.5.
To check if you are selling the correct tire size, you should refer to the tire spec on the manufacturer's website and it will show the range of wheel width suitable to be mounted on.
This is 100% correct, the size itself doesn't really matter as long as the overall outside diameter is the same, or very very close. What about just buying 4 of either the fronts or rears so you don't have to worry about it and you can rotate all the way around?
robertrios
02-15-11 06:46 AM
