Day time running light ( Low Beam )
Dose anyone know what we can replace our low beam lights with?
I find the low beams are not bright enogh. I purched a set of Sylvania H11LL
But the socket was not the same as the stock Lexus.
The bulb type you require is 9005. Looks like from doing a quick google search it looks like you yourself a H11.
For me, I gotten myself a set of PIAA bulbs. Overall it is brighter but could be more brighter because if I recall correctly, in DRL mode it is running at 30% power. It is only when you use your high beam it goes to 100%.
Also if I recall correctly, H11 is used if your car did not come with HIDs.
H11 is the for the low beam headlight, you'll want to get 9005 for the high beams/DRLs. Here's a post with a listing of bulb types for our cars. https://www.clublexus.com/forums/is-...ting-mods.html
What goes in the lowbeam depends on if you have HIDs or not.
If you have HIDs it's a D4S... H11 is correct for non-HIDs though. Neither is your DRL though, that's the high-beam bulb.... it's not really supposed to be "bright" since it's the high beam running at low power.
Personally I just had my DRLs turned off.
wait im confused...are you just trying to get hids for your low beams? cuz as brociouz said the drls are the high beams.
You could get something like this http://www.hidxenonlights.com/lexus-...sion-kit-p-183
For vehicles that do not have HID for low beams will use H11. This is probably rarely seen because since the dealer typically brings in cars which do have HIDs unless someone may have ordered a vehicle without one as in a very basic car.
RoyEP3
Lighting
07-27-06 11:21 AM
