LC 818 + Tein S Techs = Shreading Tires
Old 12-06-10 | 11:23 AM
Kybball#1's Avatar
Kybball#1
Default LC 818 + Tein S Techs = Shreading Tires
I know i have said this before, but now i HAVE to do something about this setup. My front tires are 235/35/19's.. I do not want to go back to FSport springs bc they didnt drop it enuff.. That being said. If i run 230/235s or even 230/30s. do you think that would cure the problem or am i going to have to fork over the money and get coils, which i dont really want to do???
Old 12-06-10 | 11:36 AM
IS25Heaven's Avatar
IS25Heaven
I never heard of those tire sizes before, from my understanding the width always ends with the number 5. Unless if you are measuring it by inches.
Whats your current wheel offset?
Im running 8.5 +22 with a 225/35 slammed with about -2.5 camber. I really should have gone with 215/35 because i still rub.
You should take some pics and show us where your tires are shredding. its most likely the bumper that, you either have to remove it or shave it.
Old 12-06-10 | 11:43 AM
MashinA's Avatar
MashinA
225/30 tire should help out and also search the forum there is a thread on shaving and relocating the tab that holds the bumper to the fender, thats usually where the rubbing occurs. you shouldnt have any problems with this set up. im running 225/35/20s and im ok.
Old 12-06-10 | 11:59 AM
Kybball#1's Avatar
Kybball#1
I ment to say im running 235/35s in the front and wondering if i need 225/35s or 225/30s....
Old 12-06-10 | 12:04 PM
Rolando's Avatar
Rolando
You should get 225/35/19, that's the set up I'm using and I'm running +22 in the front the only problem i had was with the bumper tab. I'm also running s-tech. No rub only when i go through a real big dip. The next choice if that does not work is to get the front fender rolled.
Old 12-06-10 | 12:10 PM
montgb's Avatar
montgb
225/35 is your answer.
Old 12-06-10 | 12:36 PM
Kybball#1's Avatar
Kybball#1
Mont, if i go with that size, will i have to roll or cut that tab?
Old 12-06-10 | 12:38 PM
vinconist's Avatar
vinconist
No need to rool cuz there's not much to roll, ur gona need to relocate the tab though
Old 12-06-10 | 12:40 PM
TRD350's Avatar
TRD350
how do we relocate the tab??
Old 12-06-10 | 02:10 PM
JMcDonald's Avatar
JMcDonald
Old 12-06-10 | 02:11 PM
Dexterr's Avatar
Dexterr
225/35 is your best friend. And your tire shredding problems will be gone for good.
Old 12-06-10 | 02:16 PM
montgb's Avatar
montgb
Depending on your drop, you might have to shave down the tab. However, you're just running springs, right? You shouldn't have any problems.
Check out the LC818 "Wheeldude Car of the Year" thread. I'm dropped on coils and have no issues whatsoever. My friend damaster32 is dropped even lower on coils and cut his tab. I think he only rubs at full turn.
We're both running 225/35 in the front.
Old 12-06-10 | 02:24 PM
Dunkin1222's Avatar
Dunkin1222
I TOLD YOU TO GET THE IS-F
Old 12-06-10 | 02:26 PM
Kybball#1's Avatar
Kybball#1
Yea, mont im just on Tein S Techs, and my poor two front tires are hurting. Hopefully when im ready ill just get the 225's and my problem will be solved..
Old 12-06-10 | 02:51 PM
simple's Avatar
simple
Ur fronts are 235, that's actually my rear tire size. My fronts are 215, I like the stretched look.
