Anyones dash rattling and popping really loud???
Old 01-19-12, 10:59 PM
  #106
stanjohn12
stanjohn12's Avatar
Originally Posted by sangomaru
Yes, have the dealer remove the bezel and re-insulate. The problem comes from the bezel and appears to loosen over time. You may have one side of your bezel with a small gap between the dash and bezel, while the other side is completely flush. I had this fixed at the dealership today, so far no more noise. Although, a road test will be needed for them to determine.
Yes thanks Sangomaru. Will tell them to do this. I can't afford to go every week to the dealership for this issue. They keep my car there like for 2-3 days and I can't live without my baby even for one day .
Old 01-20-12, 09:43 AM
  #107
rog1206
rog1206's Avatar
Try doing the fix in post 92 & 93. My rattle has been gone for months and I forgot about it until I saw this thread again.
Old 01-20-12, 10:18 AM
  #108
stanjohn12
stanjohn12's Avatar
I'm still under warranty and someone here advised me that it's better to get it fixed under warranty even if it's a hazzle taking it to the dealer a few times more.
Old 01-23-12, 08:55 AM
  #109
stanjohn12
stanjohn12's Avatar
Just to keep you all updated. Just got my car back today. I instructed the service advisor to put foam/extra padding where ever necessary and that I can't keep coming every week for them to keep tightening the screws. He assured me that this time they had removed the dash and put in extra foam in places where there were gaps.
It's super silent inside now and I just hope last week was the last time I heard those annoying noises. Fingers crossed.
Old 01-24-12, 12:00 PM
  #110
BamaIS
BamaIS's Avatar
My 2006 was popping when it was cold from the area on top of the dash between the windshield and the dash. I cut up an old T-shirt and rolled up a couple of small pieces of cloth (cut to 3"x 10" strips). Then I took a long screwdriver and pushed these pieces of cloth down between the windshield and the dash (to the right of the defrost vent on the passenger side and to the left of the defrost vent on the drivers side). I pushed them far enough so they can't be seen. My dash is now silent, even in the coldest weather. I had a new windshield installed last week and the service tech took them out. The pop was back. Did the cloth trick again and it went away. It's a cheap fix if your car is out of warranty like mine. Foam or something similar would work as well.
Old 01-30-12, 07:29 AM
  #111
stanjohn12
stanjohn12's Avatar
Smile
Thanks BamaIS , will keep this trick in mind if it happens to my car in future :-)
Old 10-12-12, 03:41 AM
  #112
stanjohn12
stanjohn12's Avatar
Unhappy
Oh man , the noise around my instrument cluster is gone but now there is a slight noise coming from my NAV unit when going over rough grainy roads. The noise goes if i exert some force over the top of the unit downwards.
Bad part is my warranty got over last month
Mine is the 2010 IS , anyone else have this problem ?
Old 10-21-12, 03:54 PM
  #113
Gymniac
Gymniac's Avatar
On a not-so-perfect road, I hear some awful rattle from the passenger side. I want to say it's coming from the "drawer" on that side and it's really awful. But on a smooth road nothing.
Anyone with same problem?
Old 10-23-12, 10:27 AM
  #114
stanjohn12
stanjohn12's Avatar
Smile
Maybe you haven't fixed the tray properly after changing your A/C filter. Make sure its fixed properly.
Old 12-06-12, 12:47 PM
  #115
bblaisdell
bblaisdell's Avatar
Great idea, I'll be trying it shortly. My 2007 IS250 has been rattling since purchased a year ago. This web-site is great for ideas!!
Old 09-29-16, 11:37 PM
  #116
mreddy
mreddy's Avatar
Default Thank you!!!!
You sir are the Man. I had been really suffering. Your fix cured the rattle completely in all of 5 minutes. It had become a miserable driving experience until I found your post. I made sure to place 3 layers of tape all around the 90 degree edge of the lower panel where it makes contact with the black bezel. I noticed a bit of a molding imperfection on the lower part where a bit of plastic was sticking out, which I suspect was making contact with the bezel and causing the noise.
All this time I had been trying to make the noise go away by crudely wedging folded paper between the plastic gauge cover and the bezel to no avail.
Here's the part I was talking about:
This is how you remove the side piece so that the lower trim can be removed. Using your fingers is good enough:
Pulled out
Now just pull the lower trim outward and it should pop right out. I put the electrical tape on the edge where it touches the upper trim
Hope this helps!
Old 10-02-16, 01:04 PM
  #117
mattmatt57
mattmatt57's Avatar
Wonder how many people have gotten there extended warranty on dash done.
Stun350
03-12-12 09:46 AM
costanza
01-14-08 06:50 PM
bsims_01
10-26-07 01:17 PM
trio
05-30-07 06:20 PM
shmelvin
RX - 1st Gen (1999-2003)
11-26-02 11:54 AM
Quick Reply: Anyones dash rattling and popping really loud???
