Quick question about HIDs
Don't flame me for this, I can't search on my phone but, when changing out the stock HIDs, is it just plug and play? Such that, I don't have to purchase a brand new kit and ballast, etc. Can I just buy the bulb and change it out, or will some adjustments need to be made?
Also, any suggestions on the best place to buy some bulbs? Quality kind.
Sorry, I'm such a newbie when it comes to technical stuff like this. Thanks in advanced!
Btw, does anyone know the temp of the stock HIDs on Acuras and BMWs? They're noticeably "whiter/bluer" than the stock HIDs of Lexus. I'm looking to get that color, but not sure what temp to choose.
Yes, it is plug and play - you just swap bulbs (D4S).
I suggest you buy Garax bulbs, which you can get on eBay for about $90. Check out forum vendors too to see if they carry them for a good price.
Lexus OEM HID bulbs are 4100K in color. Like SB350 said, BMWs and Acuras usually have the same color temperature, but they have better projectors so they flicker and look different (more blue) from non-direct angles.
4300~ would get you similar color output. You just wont get the colorful flicker that other projectors can produce. It'd be a lot more time and work to retrofit other projectors into our headlights, seeing as our cutoffs are really weak (not to mention terrible light output)
get a set of the Garax 6000k d4s bulbs and you should be good. if not, try out a set of 5000k bulbs. 6000k has a hint of blue if you look at it from a specific angle. You can pick up a set of garax bulbs from our vendors section. Pretty good quality bulbs.
Just keep in mind, if your car came with HID headlights then all u need to do is just switch out the d4s bulbs and your good to go.
However, if your car does not have HID head lights, you will have to buy a kit.
Former Sponsor
If you have factory HID's already, all you need is a pair of D4S bulb replacements.
Rule of thumb when changing out HID bulbs, is to change both at the same time to avoid the possibility of color decay differences between the 2 bulbs.
You have factory Denso ballasts running Philip D4S bulbs, don't swap them out for cheap D4S replacement bulbs, either get genuine Philip Osram bulbs or higher quality ones such as Garax or Morimoto which I believe are both manufactured in Japan.
