From H&R springs to BCR coils w/pics
Old 12-13-10, 07:04 AM
  #31
Acingteam
Acingteam's Avatar
Originally Posted by A1Lexis
Thanks guys! I'm leaving the back the way it sits now and next weekend I wil use the heat gun and melt the liners...then slam the front. My offsets are not aggressive so no need to roll or pull fenders.
Hey, do you know the offset, wheel width? Did you get any camber plates or is this with no camber adjustment? Thanks!
Old 12-13-10, 07:50 AM
  #32
A1Lexis
A1Lexis's Avatar
Thanks guys! Front is 19X8.5, 23lbs, +28. Rears are 19X10, 26lbs, +43. No camber plates or camber adjustment needed.
Old 12-13-10, 09:03 AM
  #33
Acingteam
Acingteam's Avatar
Cool, thanks man, looks nice. Do you have a shot from the back a little farther from the car so you can see the rear tires? Just kind of want to see the stance... are the wheels perfectly straight or do you have a little negative camber from lowering them that far?
Old 12-13-10, 09:23 AM
  #34
A1Lexis
A1Lexis's Avatar
I don't have any far away shots of the rear but there is some negative camber....but nothing aggressive.
Old 12-13-10, 03:38 PM
  #35
brociouz
brociouz's Avatar
Nice drop! Does it rub on turns much?
Old 12-13-10, 03:51 PM
  #36
A1Lexis
A1Lexis's Avatar
Thanks man! Only if the wheel is turned to the extreme left or right. Before the install, I read a lot of your old threads and have seen pics of the damage to your fenders and learned from that
Old 12-13-10, 03:57 PM
  #37
brociouz
brociouz's Avatar
Haha, good! Now I can sleep soundly at night knowing my fender damage didn't happen in vain. :
Old 12-13-10, 04:09 PM
  #38
projectdna
projectdna's Avatar
Originally Posted by JMcDonald
^^^ The coils are still gonna settle a little bit, I told him let them settle then we will take a heat gun to the front liner and slam the front so it looks good.
looks great.
just curious though, why are you letting coilovers settle? thing is, if you (actually/correctly) reset the bushings, there should be no "settling".
case in point:
https://www.clublexus.com/forums/sus...ere-first.html
(see post #8.)
but i'm sure you guys did it correctly, right?
Old 12-13-10, 04:17 PM
  #39
MashinA
MashinA's Avatar
Are u sure ur front offset is 28 and the rear 43
Old 12-13-10, 04:26 PM
  #40
JMcDonald
JMcDonald's Avatar
Originally Posted by projectdna
looks great.
case in point:
(see post #8.)
There are still springs on the shock, regardless...the springs will " soften " or settle a little. I been doing this a long time and every one of my coils settled a tad bit.
Old 12-13-10, 04:50 PM
  #41
A1Lexis
A1Lexis's Avatar
Yes sir, that is correct
Old 12-13-10, 05:09 PM
  #42
projectdna
projectdna's Avatar
thanks for pointing out the obvious, but you're more likely to have issues with your bushings before the springs on your buddy's coilovers "soften" or "settle a little".
don't get me wrong; the stance looks great (though admittedly this isn't the first 2is here that's on coilovers, but i digress). however, if your experience can compensate for not resetting the bushings, then all the best.
Old 12-13-10, 05:13 PM
  #43
MashinA
MashinA's Avatar
So u have no fender mods and 28 offset and no rub?
Old 12-13-10, 05:16 PM
  #44
Pnuge88
Pnuge88's Avatar
looks good! coils are the only way to go!
Old 12-13-10, 05:24 PM
  #45
A1Lexis
A1Lexis's Avatar
No fender mods at all. I am rubbing on the front plastic liners but that will be taken care of with a heat gun. Then lower the front a little more.
Quick Reply: From H&R springs to BCR coils w/pics
