A questions about spacers and lug nuts
I ve spent the last three weeks figuring out everything for my new set of wheels
I HAVE A 2006 lexus is 350 stock height and bought
19x8.5+35
19x9.5+45
235 35 19
265 30 19
i go to get everything put on and since i have 5mm spacers to clear the brakes in the front, the studs aren't long enough to screw enough times to be safe. THey said the lug nut only spun around 2 and a half times which they wouldnt let me drive off with.
So now i guess i need extended lug nuts?
can anyone tell me which ones to get
how long i should get them
etc etc
any suggestions help anything would be nice
thank you
PICS WILL BE SOON THE CAR WAS JUST PAINTED FLAT BLACk
19x8.5+35
19x9.5+45
235 35 19
265 30 19
etc etc
thank you
Yea your going to need extended studs, These will work, buy 2 sets from this guy. Good Luck man, replacing the studs isnt too bad. I did quite a few on my older cars.
http://cgi.ebay.com/ebaymotors/ICHIB...item3ef477175d
you don't need extended lug nuts. you DO need extended wheel studs.
if you bought ichiba type I spacers, they should have come with the kit. if not, you will have to buy new wheel studs.
you can get extended wheel studs here...
http://www.ichibausa.com/toyota.html
or ask one of CL's authorized venders to shoot you a quote.
Forum Administrator
![](https://www.clublexus.com/forums/images/ranks/rank-admin2.gif)
skotty,
Please use a descriptive title when you start a thread in the future (updated this one for you). "HELLPPPPP HelPPPPPP HELPPPPPPPPPPPPPPPPPPPPPPPPPPPP" just makes a lot of people not want to help.
Thank you.
Thank you.
yeap try to getatleast 6 to 7 spins before they get tight.
the 5mm in the front would be perfect balance between looks and convenience. ann on the rear you can get a 10mm spacer to flush it
stvincent
Wheels, Tires & Brakes Forum
10-18-08 04:51 PM
