Rev match???
#48
Wow the knowledge level and IQ here has dropped so rapidly lol.
I guess if I drive a manual and jam my gear from 5th into 3rd and the engine jumps to redline means my manual is rev matching too.
So wonderful, that means ever since the 1900s cars have been auto rev matching!
#49
[QUOTE=06isDriver;6012217]
What did you guys talk about? did you tell them to give us an ecu upgrade for rev matching? QUOTE]
I tried to make a pitch for a G37S inspired IS350. Something between a 350 and an F. Like a 335 fits between a 328 and an M3. If Lexus' spin on a sport sedan is to build a more luxurious version, then there are at least 3 things that would please a performance oriented enthusiast while not detracting from a luxurious experience AT ALL.
They are:
-An AT that rev matches downshifts
-Substantial multi-piston fixed calipers combined with large diameter and thick rotors
-LSD
I even suggested add'l mods such as larger sway bars, tighter and lower ride height springs, and quicker ratio steering. I told him they could stand to take a peak at the Infiniti and BMW play books. I also said that in an order to keep costs down they could use their existing F-Sport line and ISF parts to do it.
-ISF style rev-matching downshifts, but maintain the IS350 trans
-ISF brakes
-ISF LSD
-F-Sport Sway bars
-etc.?
I told him there are probably plenty of drivers willing to spend another $4k-$7k on a properly prepared "sport" package from the factory.
I also told him that only allowing their products to be avail. through a dealer parts dept. instead of having an opp. to buy a car with everything in place from the factory gives a Ford Racing or GM Performance Parts feel to things. Not that I have a problem with either of those divisions, but that approach probably doesn't have the same appeal to a Lexus buyer.
I think that was all. I hope he took notes.
They are:
-LSD
-ISF brakes
-ISF LSD
-F-Sport Sway bars
-etc.?
#50
Let's take a poll. Everyone here who knows what a torque converter is, raise your hand. Of that group, everyone who knows how one works, keep your hands raised. Everyone else, shut up.
When you force the transmission down a gear, the converter forces the motor to spin up. This is not the computer opening the throttle to match the rpm to the new speed of the trans.
#52
FYI, if you triple tap the paddle up and then tap it down it will shift you into 5. I've done it a few times, though the last time I did it, it dropped to 3 but i think its because i wasn't going that fast. More testing coming...
#53
You can't shift the car directly. The only thing you can ever do is lock out higher gears from the allowed range for the automatic transmission to pick from.
#54
Definitely. I would love to do this. But I do not have a companion with me who can do that and understand what I am trying to do. Need to find one. Anyways, here is what my car does. Tell me if this is blip or I am misunderstanding one for the other.
Car is in S mode. 4th gear. 40mph and accelerating.
my foot is on the gas, pressing the pedal down.
I hit '-' paddle and
i. the rpm shoots up
ii. an instant later the gear change to 3rd happens and there is no jerking or engine rearing up effect.
In essence, the computer has shot the rpm to where it should be after the gear change, but before the actual gear change happened.
I really need to make a video, but it is very difficult to do it with the camera in one hand.
Need to somehow stick the camera to the steering wheel.
#56
After driving cars for over 25 years now, half of that using stick shifts, I think I do understand when the engine rpm is shooting up from gear engagement and when it is not. Please don't be so adamant. There is something different about this scenario that I am talking about.
#57
whats more logical in this scenario:
1. That your particular car has a completely different ecu that allows and can calculate for rev matching while no other isx50 auto in the world can?
2. That you may be mistaken on what you feel you are experiencing.
Go test drive the infiniti g37 and you'll know what rev matching is, you'll KNOW.
rev matching is the one thing I miss from the infiniti brand. i know the isx50 does not do it.
#58
An automatic transmission uses several one-way clutches. These are like on a bicycle which allows you to coast without pedalling. So in a normal automatic in Drive, when you are not pressing the gas such as when you are coasting or braking, torque from the wheels is hardly transmitted back to the engine. Because of this, there is no rev matching on downshifts (in Drive).
However, the way the IS auto is designed, it does have engine braking (torque from the wheels is transmitted back to the engine) in gears 4, 5 and 6 (D or S modes), as well as the highest gear in S3, S2 and S1 modes. So if you force a downshift by going into a lower S mode, the torque from the wheels will push the revs up, but this is after the shift. There is no 'throttle blip' to match the revs before or during the shift.
Also the torque converter in an auto reduces the torque transmitted from the wheels back to the engine, and reduces driveline shock. This also makes rev matching unnecessary.
Auto and manual transmissions are so fundamentally different that it is foolish to try to imitate driving practices from one to the other.
#59
#60
Rev matching is a very specific phenomenon, and no ISx50 has it. You're just flat out wrong; I don't know how else to put it.
