Rev match???
#61
After driving cars for over 25 years now, half of that using stick shifts, I think I do understand when the engine rpm is shooting up from gear engagement and when it is not. Please don't be so adamant. There is something different about this scenario that I am talking about.
How did you downshift your manual cars....foot off the gas, clutch in, shift to lower gear, clutch out, and let the engine 'rev match' by itself? lol
Your car does NOT have rev match, sorry man.
#62
Also the torque converter in an auto reduces the torque transmitted from the wheels back to the engine, and reduces driveline shock. This also makes rev matching unnecessary.
Auto and manual transmissions are so fundamentally different that it is foolish to try to imitate driving practices from one to the other.
1) hold the current gear until paddle input is received
2) shift immediately once paddle input is received
3) rev-match on downshift
If Lexus would offer a programming upgrade to correct this massive fail, I'd pay good money for it
#63
that may be a good mantra for the folks over at Oldsmobile (notice they aren't around anymore), but for a 'sport sedan' like the IS - with paddles no less - they should have programmed the tranny to behave like the IS-F: in auto (D), it behaves like a slushbox. Fine, great for rush hour traffic. But in sport mode/manual mode/whatever you want to call it, it should do three things:
Except the paddles aren't shifters, so there's nothing for Lexus to 'correct' other than perhaps their choice of words in marketing material.
They are top gear limiters. Period.
#64
However, if my foot is not on the gas pedal, there is no rematch. In that scenario, the revs increase merely due to engagement to a lower gear and it is not very pretty because there either is a driveline shock or engine braking observed.
#66
The paddles aren't shifters. The automatic transmission will always put the car in the most appropriate gear within the allowed range.
You can't shift the car directly. The only thing you can ever do is lock out higher gears from the allowed range for the automatic transmission to pick from.
#67
exactly...thus, your car does not have rev-match. Do that in a car that does have it, and the tranny will automatically blip the throttle to bring the RPMs up for the lower gear's engagement
#68
I knew what they were when I bought the car, but couldn't justify taking out a loan to cover the $20k difference to get into an IS-F for this feature and the better front seats. Don't care too much about the 5.0 since it sounds like a NASCAR motor. I'm happy with the 3.5.
I hope (and somewhat expect) the next gen of products from Lexus does not deliver false 'sportiness', or else the competition will leave them further behind and I will move to another brand.
#69
Or you could be entrepreneurial and engineer your own transmission control unit, then sell it for $$.
#70
correct....but the difference is that the revs increase before the actual engagement. i.e. it increases in that interval when it is neither in the 4th or the 3rd gear in my example. That window is so small that it is not able to get to redline and what actually ends up happening is that a revmatch is achieved. It may not be by design,but this is what does end up happening.
#71
My 2003 mazda6 stickshift had that blip feature where the computer would gently blip the rpm when I disengaged the clutch so that the gear engagement wouldn't be such a shock. Too bad it was not a very good implementation and it was eventually removed in subsequent ecu flashes.
