Rev match???
Old 12-17-10, 01:08 PM
jaxxx
jaxxx's Avatar
Default Rev match???
Is350... When downshifting using paddles does it rev mAtch??
Old 12-17-10, 02:18 PM
mikez
mikez's Avatar
No, unless you use your foot.
MikeyStyle (05-15-21)
Old 12-17-10, 02:38 PM
Initial B
Initial B's Avatar
no rev match....one thing I truly hate about this car
Old 12-17-10, 03:15 PM
juice14
juice14's Avatar
probably the new IS will have it
Old 12-17-10, 05:07 PM
IS-J
IS-J's Avatar
Not unless you do it yourself, by down shifting and then tapping the accelerator to about 50%. I do it all the time but it does take practice, lol
Old 12-17-10, 08:49 PM
Kurtz
Kurtz's Avatar
It's impossible to downshift with the paddles. The paddles aren't shifters. They are top gear limiters.
Every time you try and think of or use them as shifters you will be disappointed in them.
Old 12-17-10, 08:59 PM
Acingteam
Acingteam's Avatar
That's not true. Even though they are limiters, they will make your car downshift. Say your car is in 4th gear and you set the limiter to be a 3rd gear, the car will downshift to 3rd.
However, it is impossible to upshift using paddle shifters.
Old 12-18-10, 01:11 PM
Kurtz
Kurtz's Avatar
Yes, the car will. Because it's no longer allowed to use anything higher.
That's quite different from directly shifting. (which a manual, or the automatic in the IS-F, can do).
If your car was in 2nd though and you paddle down from 4 to 3, nothing happens.
That's why it's so slow to use the paddles in the ISx50. Because they aren't shifters.
Old 12-18-10, 01:21 PM
chris07is
chris07is's Avatar
1000000000x^^^^ agree!!!
Old 12-18-10, 04:56 PM
mikez
mikez's Avatar
If the car's auto computer is still in 2nd, and you put your S mode in 4th, I fear the bigger problem is your bad choice of gears lol
Old 12-18-10, 08:04 PM
Kurtz
Kurtz's Avatar
FYI- 4 is the default it puts it in when you first move the stick into S mode
The main point was you never directly shift the car... the only thing you can ever do it lock out, or allow, the higher range of gears as available or not to the fully automatic transmission.
Old 12-18-10, 09:07 PM
chikoo
chikoo's Avatar
either ways, I think it is a good implementation. you get to downshift on-demand and then the computer takes over of downshifting even more if needed.
Old 12-18-10, 09:10 PM
chikoo
chikoo's Avatar
I guess my 250 does...I have not felt the car slow down(or rear up) when I downshift.
Old 12-18-10, 10:40 PM
Raralith
Raralith's Avatar
What? It's a terrible implementation! Should have got the F transmission.
Old 12-18-10, 11:01 PM
SGMIS3
SGMIS3's Avatar
If you are going fast enough, it will actually put it in 5th gear when you move it to S gear.
Quick Reply: Rev match???
