So I am pretty much a noob with modding and i installed a megan racing axle back exhaust and hand tightened everything. I herd some like shaking .I then got the invidia mid pipes installed by someone else and i hear some clanking sounds. I think i may not have tightened the axle back enough has anyone had a similar problem?
Re-using the OEM stock hangers would have been adequate. Like others have said, go look under the car to see whats wrong, loose, or out of place. Good luck.
exactly why you never have anyone but yourself install something as simple as an exhaust. aftermarket exhaust wont have 100% fitment. there will be some tweaks needed here and there to have satisfying results
okay thanks, one of my friends said i may need to get hangers
would that help?
You use your OEM hangers.
I'm blanking on the name of it right now, but there's a little piece that almost looks like cardboard that goes in the space between your exhaust and midpipe, where it bolts together. If it's not there, you'll have metal hitting metal, which could be causing that sound.
The main bolt should also be tightened with a torque wrench, but I doubt it's causing that sound.
