noise from the driver side:(
i noticed today there was noise from the drive side window/door area im not sure where the noise came from, but it happens when i drive on uneven road and it drive me crazy, does anyone else experience this problem too? or just me?
Did u remove everything in the door pocket? Perhaps there something in there that rattles.
Also, is it a consistent noise?does it occur at certain speed? or over bumps?
My wides Acura has this strange rattle only at 30 mph or above. We later found out that it was caused by loose weather strip picking from wind and slapping back on glass.
I have the same problem, i have no idea where its coming from but its around the driver side also. Any recommendations? Will the stealership fix it for free if its under warranty?
I feel your pain. I have the rattle you speak of, as well as a rattling passenger door pocket rattle, and a glovebox rattle. I have to turn the music higher than normal to mask the rattles. If I, or the dealership, can't figure them out then I plan on selling the car because it is ridiculous.
If you have the driver's seat all the way down raise it a bit. If it goes away tighten the seat track bolts.
Take everything out the glove box,...including the shelf and cover for the cabin air filter,...see if the noise rattle goes away. If the noise goes away, put in one item at a time,...that cabin air filter cover only goes in one way correctly.
From what Ive read, it's pretty normal and often when they fix noises like these, other ones pop up. I'd leave it alone if its not a simple fix or if it is livable.
I used to be a rattle non-believer....
I have this--it sounds like it's coming from the B-pillar, right next to my ear. Or maybe one of the door panels. I also am getting a rattling from the sunroof piece that pops up in the REAR of the sunroof opening when the SR is in tilt.
My warranty is up in May, and I need to give it a shot to have the dealer remedy these. Drives me crazy.
After 7 years, my Acura that I traded for this car was solid as a rock.
If they say the car has been tested within specs, ask them to sit with you on one of the cars on the lot for a ride.
Make sure you empty the glovebox and the door pocket or other things lying around. The dealer will use that as an excuse for the rattle.
So far, my car has been rattle free. *knocks on wood*
If you have taken apart interior panels, note that the alignment of the pieces may be off a little or loose.
As much as I like my IS350 the various rattles and creaks drives me crazy. Lexus needs to do a better job on this kinda stuff. I am sure some of it is due to tight tolerances and fit and finish...particularly when the weather changes and things expand and contract..but enough!
I have the same exact problem when driving on uneven roads and my car I just bought my car in the first week of December 2010. It's a 2011 Lexus IS350. That noise was driving me crazy but I just learned to ignore it or I just turn up the stereo LMAO I thought it was because I have the sport suspension= slightly stiffer ride
