finder rolling question! need help!
i believe the pic is used for reference's sake and not necessarily his car per se, but given the assumption that it is the rear fender tabs that are causing the clearance issues...
regardless, i've ran everything from 235/35-19's to 255/35-19's 19 x 9.5 w/ a +22 offset, and i have plenty of clearance from rolled rear fenders and shaved fender tabs.
the OP's clearance issues in the rear are not from the edge of the fenders but the fender tabs located where the rear fender meets the rear bumper.
in case you haven't been following your own thread...
(bolded for emphasis)
just to save the trouble of repeating myself.
you need an alignment to save your tires, but it shouldn't have anything to do with wheelwell/fender clearance.
the fender tab is at the point where the fender meets the bumper assembly - one at each corner.
depending on your ride height, you may or may not need to make alterations to the fender tabs.
LilMan23
CL of Southern California
02-11-10 07:19 PM
