Wire connector melted!
12-23-10, 11:06 PM
So I decided to order some Nokya yellow 9006 bulbs for my fog lights about 5 months ago... Last week one of them went out so I ordered a new set. After putting the new bulb in I realized that my connector is melted! Anyone with similar problem and what can I do about this?
12-23-10, 11:21 PM
i have the nokya fogs too and one side went out couple days ago too.. i hope its not the wire (havent had the time to check it)
12-23-10, 11:21 PM
Yes. I drove the LFA.
What is the wattage on those Nokya bulbs?
12-23-10, 11:39 PM
"55w" on my bulbs and I do see some bulb with something like 80W?
12-24-10, 08:49 AM
That's happened to me too, twice. I had my tech co-worker repair the wiring. Now I have been using the 3000k HIDs.
If you do purchase a new set, make sure to get the 55w ones. The ones that caused mine to melt was the 70w nokya bulbs.
12-24-10, 09:01 AM
same thing a had to replaced the female connector. cut and soder. its a pain in the butt. let me know what you end up doing.
12-24-10, 05:13 PM
dont know what im gonna do. Its working now but I dont know if i should leave it on still.
12-24-10, 05:39 PM
Auto parts has a high heat plugs to replace the stock plugs
12-24-10, 08:29 PM
Royale with cheese
http://www.automotivelightingusa.com...y-duty-harness
buy these. cut off old connectors, strip wires, solder/crimp and put heat shrink tubing/electrical tape.
clean connectors with electronics cleaner then apply dielectric grease on connector and then connect the bulbs.
12-24-10, 10:24 PM
Didn't I post that you need the high wattage harness not too long ago?
Anyways you need this:
12-24-10, 10:56 PM
Quote:
Originally Posted by
iSuxeL
and where can I find that?
12-24-10, 11:01 PM
Guess I better check my harness since I get the 55w ones too. I been wanting to do the HID fog but I don't know if I want to remove the bumper.
MYTOYLEX
10-15-12 09:40 AM
Nash
04-29-10 09:58 AM
ADAM P
Lighting
07-04-06 11:57 AM
sputniknyc
Lighting
01-30-06 06:40 PM
Skulinex
SC- 1st Gen (1992-2000)
25
09-26-02 02:30 AM
250 ,
9006 ,
bulb ,
connector ,
connectors ,
electrical ,
fixing ,
grease ,
harness ,
lexus ,
melted ,
melting ,
nokya ,
socket ,
wire ,
yellow
