Nokya Fog Light Installation
i've installed many nokya fogs in local members cars... you're pushing it in and it feels like it doesn't fit? its too long? well it isn't just feels that way~ you need to get it dead on straight and then just push it in... BUT~ don't use too much pressure cuz one member here did it himself and broke the bulb inside the housing ![Egads!](https://www.clublexus.com/forums/images/smilies/pat.gif)
best way, put it in and look at the light from outside to make sure its aligned in the cap thingy BEFORE you give that final push, or have a friend look while you're pushing.
Switch out the o-ring from your stocks bulbs to the Nokya bulbs. I had that same problem and when I looked, the o-ring where a different size, not by much but enough to make it not install correctly.
SeanIS350
02-05-12 08:07 PM
