Electric Short
Old 12-30-10, 03:22 AM
JKellz
JKellz's Avatar
Default Electric Short
Monday night, went to bed. Woke up in the morning to see 3 out of 4 of my windows open and my sunroof partially open. And that night, noticed that my passanger side headlight was out. Has anyone had this problem with their car? I havent done any work to it yet, the car is completely stock. I either blew the bulb or ballast on the drivers side so I will just buy a new set of lights to replace both sides. How bad is it to replace the headlights and ballasts in the car? Plus, do I need to be worried about the electrical system in the car?
Old 12-30-10, 05:25 AM
Bichon
Super Moderator
Bichon's Avatar
The open windows and sunroof was no doubt caused by something in your pocket accidentally pressing (and holding) the open button on the key fob. This happened to me at work shortly after getting the car, so I had the dealer turn off the "hold open button to open windows and sunroof" feature.
I'm pretty certain the problems with your HIDs are completely unrelated to this.
Old 12-30-10, 05:39 AM
IXI187IXI
IXI187IXI's Avatar
^ I agree. most the time when the windows and sunroof automatically open its usually from people not knowing they are pressing on the fob. the hid problem is probably just a bad bulb
Old 12-30-10, 06:48 AM
JKellz
JKellz's Avatar
ok well i didnt know about the hold unlock for the windows feature but it only did 3 out of the 4 windows. and i know for a fact it wasnt that because my keys were on the table from when i got home until i went to work the next morning. i went outside for several cigarettes throughout the night and my windows were never down at any of those points. and just a few hours after that is when i noticed the headlight problem. when i parked the car that night, i had no problem with the headlight. came out the next morning to the windows open and the passanger side headlight no longer working.
Old 12-30-10, 06:49 AM
JKellz
JKellz's Avatar
how hard is it going to be to replace the ballast and bulbs in this car? the foglights were a ***** and i really dont have the patience to take the bumper off again
Old 12-30-10, 06:55 AM
IXI187IXI
IXI187IXI's Avatar
i highly doubt its your ballast. try swapping the bulbs (ie put your passenger side bulb in the drivers headlight) as see if the problem is the same. If so then you know its the bulb and not the ballast. To change the ballast you have to remove the headlight which requires removing the bumper. The ballast is located under the headlight on the side closest to the fender.
Old 12-30-10, 07:15 AM
JKellz
JKellz's Avatar
damn. this is going to be a project. im pretty sure i regret buying this car and should have bought the 350z i had my eyes on. this thing has been nothing but problems since i bought it lol
Old 12-30-10, 07:18 AM
IXI187IXI
IXI187IXI's Avatar
eh i wouldnt worry too much about it. the car is an 07 so its not uncommon for a bulb to go bad already (which im pretty sure its just the bulb). the windows thing is probably just one of those freak accidents that happen and will probably never happen again.
Old 12-30-10, 08:09 AM
EJC
EJC's Avatar
Why only 3 of the 4 windows open?
Old 12-30-10, 08:11 AM
EJC
EJC's Avatar
Shouldn't this all be warranty work?
Tracking a short should be the dealers problem not yours on a STOCK car
Micaiah
Micaiah's Avatar
Is your car under warranty? Maybe you can call Lexus and see if they will look at the window situation.
StealthAWD
05-31-15 05:59 PM
sebast
11-09-12 09:57 AM
Nathan H5
GX - 1st Gen (2003-2009)
09-15-12 10:44 AM
dcarlson
04-17-07 09:00 AM
Seattle350
05-05-06 01:49 AM
Quick Reply: Electric Short
