F-Sport Mesh Grille Upgrade
Old 05-28-11, 12:02 AM
  #151
bjw1978
bjw1978's Avatar
Originally Posted by CalMike
Unfortunately, you would have probably had a much easier time had you actually left the hooks in the weather stripping and simply used a pliers to pinch the other end of each hook out from where they attach to. This way would make attaching the weather stripping back a much less painful experience.
No worries though. At this point, your best bet is to use a pair of needle-nose pliers to hold each hook and carefully twist it into its hole on the weather stripping. Go slowly, one by one. It could take a little while but you're much better off taking your time than ripping any of the weather stripping.
Thanks for the advice, CalMike! I'll definitely try that tomorrow.
Old 05-28-11, 12:38 AM
  #152
icrash
icrash's Avatar
I know it's kinda LOL question but has anyone found '09 lower zig-zag grille?! Or maybe modded the '11 lower grille to fit in '09?! Can't see the logic - why not to do a lower grille for '09-10??? I think there will be a lot of buyers... I am among the first!!))
Old 05-28-11, 02:06 PM
  #153
ISThree
ISThree's Avatar
see post #139
Old 05-28-11, 02:44 PM
  #154
stlgrym3
stlgrym3's Avatar
i just placed an order from Sewell for the mesh f sport grille insert for my '11 250. noticed there are two kinds of grille surrounds, f sports only cost about $75 but there's another kind cost over $200, i just settled with the insert for now.
Old 11-09-11, 09:32 PM
  #155
BE715
BE715's Avatar
I followed your instructions and it worked like a charm! Thanks
Originally Posted by pfdaxe
Hey guys:
I just installed my IS-F (replica) grille from Ebay. The fit is perfect and install took about 10 mins. And...you DO NOT have to remove the chrome surround to install! Once I removed the clips and 10mm screw from the top, I pulled off the weatherstripping that wasn't attached to the grille. There are 2 little pins on each side that come out. They came off easy. If they pull out of the weatherstripping, they go right back in with no problem. I then reached down and pushed the tabs that are on the side and bottom of the OEM insert. Once the tabs were loose, I just pushed the insert in toward the radiator and it came out. I then placed the new grille insert into the chrome surround from the back side and it snapped into place. There is no need what so ever to pull the chrome surround out unless your replacing the whole thing. I used a wide blade putty knife to pull the "L" from the OEM grille and then used 3M two-sided tape to reattach to the new grill. Very easy guys...
Before:
After:
Old 11-09-11, 11:21 PM
  #156
ChrISF
ChrISF's Avatar
your LED strips downgrade your car. nice grille though
Old 11-22-13, 08:33 PM
  #157
Ben250
Ben250's Avatar
Thread revival from the dead. I have a 2011 IS250 and wanted to install the F-Sport grille. I went cheap and got a grille on Ebay that was definitely not right. My stock original grille is on the top, what came in is on the bottom. Obviously different.
For 100% clarification, is the grille insert I need to fit my grille part number 53112-53220???? This thread also mentions a painted grille surround, part number 53111-53250. Is that the part number of the painted surround and does anyone have a picture of it? The bottom grille in the picture was verified to be from a 2011 ISF using a VIN from a 2011 ISF and matching the part numbers, this is why this is confusing.
Old 11-23-13, 12:05 AM
  #158
sichigo
sichigo's Avatar
This is the grille insert you need. the grille you bought is for 06-08
http://is.sewellparts.com/accessorie...2011/4645.html
Old 11-24-13, 01:12 PM
  #159
Ben250
Ben250's Avatar
Thanks for the link, but I am trying to get confirmation on the part number.
Old 11-24-13, 01:34 PM
  #160
sichigo
sichigo's Avatar
Part #: 5311253220. fyi, you can add to cart on Sewell website to get part #
Old 11-24-13, 01:50 PM
  #161
Ben250
Ben250's Avatar
Ok. Confirmed. Thanks!
Old 08-27-15, 05:39 PM
  #162
ALANLU
ALANLU's Avatar
i have a 2011 lexus is250 AWD non-F sport package . if this aftermarket F sport grille fit , please let me know where can i purchase this thanks
Old 12-19-15, 04:10 PM
  #163
Bkhectic
Bkhectic's Avatar
Bramautoparts.com everything oem parts bro they are located in queens but discounts are only online. Upper grille part # 5311253220
Old 07-02-22, 11:14 AM
  #164
b4u2015
b4u2015's Avatar
Hi,I am planning to replace my front and lower grill for lexus is300 model 2011 Middle East Specification that has distance radar on front logo (anti crash system) and cruise control (attached picture) I saw many post with different part number that make me more confused Can you help with the correct part number for the F sport grill front and lower that will fit perfectly on my lexus
Old 07-02-22, 01:33 PM
  #165
primavera
primavera's Avatar
Check out https://www.amayama.com/en
Quick Reply: F-Sport Mesh Grille Upgrade
