Help leaking fluid
Registered User
![](http://i20.photobucket.com/albums/b238/flyfl1pguy99/IMAG0061.jpg)
![](http://i20.photobucket.com/albums/b238/flyfl1pguy99/ISx50/leak-1.jpg)
Anyone one have an idea what the hell is this? Location is driver side rear tire area. Never had anything leak in that location. Anyone have any ideas if this is normal or bad?
If a brake line was leaking it would mean your hydraulic system isn't holding pressure = brakes won't work.
Look in your trunk...pull the spare tire out. Is there water or something in there (maybe something spilled after a trip to the grocery store)? If so there could be a drain hole in the trunk that is then leaking out...
