Any1 drive without the engine cover?
It is an Inje intake, I like it for looks and sounds nice when you step on it. As far as HP gains, don't think it's huge. None really are. I like the polished pipe and price. I was going to buy the F Sport cause it's CARB approved in CA, but it was too expensive and not polished.
Mainly the covers are there to reduce noise, and likely discourage folks from working on their own car.
Keeping them, or removing them, should make no functional difference to the operation of the car at all either way, other than arguably the "improvement" of removing like 5 lbs from the front of the car if you take em off in exchange for a louder engine.
I never have them on, its a pain to adjust the coilovers with the covers, so i just keep them alll off. I do feel like the intake filer gets dirtier faster, it might just be coincidence tho
where did you get it from?
I worked with a few manufacturers developing intakes and piggy backs for BMWs and one test was seeing if hot or having a filter located inside the engine affected power gains and no it didnt. We even tested metal vs plastic pipes.
alot of what people say here are from what they read online, few have hands on experience or has done tests
Removing the cover will not help your engine run cooler. The engine temperature is regulated by a thermostat. The only thing it could possibly do is slightly increase the time it takes for the engine to reach normal operating temperature. Since your engine runs more efficiently when warm, this would theoretically result in a (very slight) waste of fuel.
