Oem hid issues! Who else is having them?
#32
Wow, I didn't think my bulbs were going to go out anytime soon... My car is right around the age that most people in here seem to be at (07 with 46K), so I guess I can expect them to go out soon.
I hate to sound like a broke record, but where can I get these cheaper bulbs so many people are talking about? I've seen it mentioned a few times, but nothing too specific.
#35
Like a lot of others here, my driver's side is turning off. It has happened twice thus far and it appears to happen after the lights are turned on for a while then turned off for a couple of minutes, then back on, like when stopping to fill up with gas. That is what happened tonight when I stopped to get gas on the way home from work. My 07 GS350 has just over 60k on the odo. Looks like I need to start looking for replacement bulbs.
#37
Passenger side light went off today. It turns on for a second but then goes off. After a long time, it stays on but very dim. Autozone guy said this is a ballast issue and not the bulb. I have an '06 IS350 with 43K miles and extended warranty. Any idea if it is covered under extended warranty?
#39
Tech Info Resource
Never had this happen on my '06 350 or my '08 IS F. Sorry, but it isn't common at all.
#40
i have a 06 is350 with 36k miles on it and it shuts off on me quite often. flickers alot too. i also got the extended warranty and i set up an appt on the 22nd and see if they will cover if not i will get the bulbs from retrofitsource
#41
My '07 IS350's driver side bulb stays on for about 1 second when I turn it on. However yesterday it stayed on after I flicked off and than back on again. Today back to the one second deal. The car is going into Lexus on Wednesday for recall work, hopefully this issue gets taken care of under warranty also.
Just got the car back today. They replaced the drivers side bulb, and a whole new passenger side assembly because of condensation, and all of it was included in the warranty work no questions asked. Recall work done also. They even filled the gas tank to full, so no complaints from me.
