Be cautious of spacers
Wow, glad nothing happened to you! Same question, were these v1 or v2? Size of spacer?
I've read Ichibas were not as good quality as Fic or Project Kics. Maybe you'll have better luck with those.
Spacers were never the best idea. Usually it is best to get the correct wheel specs and avoid adding spacers. Afterall, spacers are just an extension and presents an opportunity for stress points. I would also question the quality of certain spacers, the quality and construction, as well as how well-engineering they are to be 100% flat as I heard low grade spacers induce vibrations and whatnot.
Good to hear nothing bad happened and you discovered the problem prior to any accident. Take care =)
thats pretty serious, i was gonna sell my h&r with exteneded studs for V2's with built in studs. extended studs would be way better cuz your wheel will still stay on if the spacers cracked completely. i guess me taking the extra time to swap studs was totally worth it.
Ever since then, I am doing lots o research trying to find the best spacers for my car to avoid such a situation again.. Problem with being a car nut is everything noise is sometimes noticeable.. :P But your guys' expertise on the matter is definitely well heeded!
Thanks.
