Navigation is terrible
Great Deal Guru
Is this the latest and greatest ??
If yes I have a copy but still need to load it on my 06 IS350. How does it gets done.....anyone?
Lexus/Toyota Navigation DVD for Gen 5 Ver 10.1 North America
U35
86271-53025
464210-1711
Data Version 10.1
ES-350: 2007 - 2009
GS-350: 2007 - 2009
GS-430/460: 2007 - 2009
GS-450h: 2007 - 2009
GX-470: 2007 - 2009
IS-250/350/F: 2006 - 2009
RX-350: 2007 - 2009
RX-400h: 2007 - 2008
Compatible Toyota Models:
Camry: 2007 - 2009
Solara: 2007 - 2009
Highlander: 2008 - 2010
Prius: 2006 - 2009
Sequoia: 2008 - 2009
Tundra: 2007-2009
Landcruiser: 2008-2010
Sienna: 2006-2010
4Runner: 2006-2009
U35
86271-53025
464210-1711
Data Version 10.1
ES-350: 2007 - 2009
GS-350: 2007 - 2009
GX-470: 2007 - 2009
RX-350: 2007 - 2009
Camry: 2007 - 2009
Solara: 2007 - 2009
Prius: 2006 - 2009
Tundra: 2007-2009
Sienna: 2006-2010
4Runner: 2006-2009
Open up your toolkit that came with the car. Inside the center spine is a flap with two long pointed tools inside. Pull these out. Stick one in each hole on either side of where the clock/emergency button is. Push both in at a slight inward angle with some force, they go in deep, maybe a couple inches worth. This will pop off the face of the dash covering the Nav DVD. In the NAV menu system (can't remember exactly where) there is an "Eject NAV DVD" button. Do that and put in the new disk. Done!
I think if you try to use the updated NAV map for travel is a waste of money
, but it is worth NO press AGREE BUTTON
, I had map data 6.1 before and I used to travel to NC and the Lexus map route me 12hrs to the destination I was entered
but the garmin it shown me 7h45 mins
so I ended up using the garmin, while I was driving through the intersection, some of the road's not even shown up in my lexus display, it shown i am in the middle of somewhere
. Anyway I thought it was the map? therefore I update my map to 10.1, but still samething when i went to NC again
still drove through the route but display still shown I am in the middle of somewhere
. In my opinion the updated map, just update addresses, POIs, ect... but it not update the route or roads, it still route me to the longer route
![Thumb Down](https://www.clublexus.com/forums/images/smilies/thumbsdown.gif)
![Crying](https://www.clublexus.com/forums/images/smilies/Peace.gif)
. In my opinion the updated map, just update addresses, POIs, ect... but it not update the route or roads, it still route me to the longer route![Thumb Down](https://www.clublexus.com/forums/images/smilies/thumbsdown.gif)
I took a 4 hour trip and inputted the destination in my car GPS. I know it only takes 4 hours as I've driven it many times but the car GPS shows 6.5 hours??? But on my Garmin it was 3.45 hours. But upon comparing the routes on both GPS's I realized they were nearly the identical routes. This lead me to believe that the Lexus GPS time to arrival is way off. This may have been your case too.
The defaults are most likely to slow than what you drive and would need to be adjusted accordingly.
Default setting is currently set as follows:
Residential:
25 MPH
Main street:
35 MPH
Freeway:
55 MPH
For me, I adjusted mine but changed it to the KM readouts and configed it this way to give a better estimation.
Residential:
30 km/h
Main street:
60 km/h
Freeway:
100 km/h
Registered User
Yeah at the same time i traveled i had the lexus nav and the garmin on at the same destination, the lexus nav keep telling me take the different route, even when return home i am about 5 mins away from my house the lexus nav keep tell me to turn around? Make a U turn make U turn ahead,that stupid lexus nav i hate it
Super Moderator
Funky
12-15-07 03:09 PM
vr4henry
10-20-07 09:23 PM
