Vanity Mirror bulb LED upgrade
Anyone know what king of LED bulb I need to use to change those bulbs to LED?
I want regular white.....
Thanks ahead of time.
this is what i used, http://www.v-leds.com/Interior-LED/D...-p5168709.html
or you can go brighter http://www.v-leds.com/Interior-LED/D...-p5768086.html
So far so good.
These are the only ones I am missing right now from my interior.
I also need the Trunk LED bulb replacement.
Mirror Puddle Light will be great.
I think that take care of all the yellowish regular bulbs in the car. With out making changes on the headlight and tail lights.
I have done already:
door entry
Map light front
map light back
door sill already came with the car in white light.
Anything missing inside? that I miss.
Thanks
door entry
Map light front
map light back
Thanks
Here is a list of all the bulbs
City Lights=168 (T10 LED) I used a 38-SMD 360 Degree White bulb and it looks great with my 4500K 55w Low beams/4500K 35w Fogs
Puddle Lights=168(T10 LED) I used a 16-SMD 360 Degree White bulb but I would go bigger...maybe 21-SMD (make sure it's a 360 degree bulb)
Map Lights=168 (T10 LED)
Dome Lights=579 (D42mm LED)
Door Courtesy Lights=194or168 (T10 LED)
Bulb Guide:
http://www.sylvania.com/ConsumerProd...RG-Results.htm
I bought all my bulbs here and I'm verry happy with them:
http://store.ijdmtoy.com/ProductDeta...XUS%5FSMD%5F09
Bulb Guide:
I just got almost all the LED's needed on ebay, less than 70 shipped.
Only issue is that the rear dome light bulbs are more purple/blue than the front ones. Still trying to figure tha tout.
Haha, thanks for the shoutout Mariano. ![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
OP, read this: https://www.clublexus.com/forums/is-...de-w-pics.html All the answers you seek should be in there.
I listened to Brociouz and got these.....http://www.v-leds.com/Interior-LED/D...68086-1-3.html. Don't regret at all. They are very very bright but that's what I want
And yes, listen to Sffd103 for the reverse lights http://www.v-leds.com/Exterior-LED/P...26829-1-2.html. They are expensive but definitely are worth it!
Thanks for the link>
I just want to change the trunk and Puddle bulbs with regular white LED bulbs, which would you say do the job?
I read all your post but it is all toward super bright or blue.
I am getting confused at this point with all the offering.
I will go with V-led but which will it be for regular white(not super bright).
For Puddle and Trunk only?
Thanks for the advise.
brociouz:
Okay, for 5000K and not as bright:
Vanity: http://www.v-leds.com/Interior-LED/D...08401-1-2.html
Trunk: http://www.v-leds.com/Interior-LED/D...54410-1-2.html
