S2000 AP2 Tips?
Old 01-14-11, 11:03 AM
JMcDonald
JMcDonald's Avatar
NoAlias, jnguyen87, you can drill the hole but I can see it being real flimsy. I would just take it to a muffler shop and get it done right and not be ghetto lol.
Old 01-14-11, 02:21 PM
TrancEpimp
TrancEpimp's Avatar
Originally Posted by jnguyen87
All these guys in this thread i linked just pulled off their stock tips and slid on the s2k tip and tightened the bolt down on the bottom apparently. The bolt assume doesnt necessarily have to go into a nut or thread into the tubing like on the s2k. It just has to screw down til the bolt hits the muffler tube if that makes sense.
https://www.clublexus.com/forums/sho...ferrerid=65984
You are right.. When you slide off the original tips, the stock muffler has a little 2" diameter, 2" long tip that you can slide the s2k tip on. The bolt from the s2k tip will tighten onto the original pipe. No Welding/Cutting needed..
Old 01-14-11, 02:25 PM
JMcDonald
JMcDonald's Avatar
Yea but how you gonna keep the tip from coming off? Lol unless you install them improperly and ghetto looking
Old 01-14-11, 02:48 PM
laobo979
laobo979's Avatar
It a bolt on not weld on. Yet to hear any member weld it on or have it fall off just from the screw that holds it.
Old 01-14-11, 04:59 PM
9relude8
9relude8's Avatar
Had my tips for over a year never welded or drilled.. Stuck on very solid too!
Old 01-14-11, 05:02 PM
KangstaxD
KangstaxD's Avatar
seriously, where do you get these tips? I go to the honda dealer and ask them for ap2 s2000 tips?
Old 01-14-11, 05:26 PM
9relude8
9relude8's Avatar
Try eBay got mine there
Old 01-14-11, 06:51 PM
wilwilB
wilwilB's Avatar
Will it fit if you have an aftermarket exhaust? or does it only fit on stock ones? cus I wanna get the Greddy exhaust but I don't really like the look of the new tip, so it would be great if I can switch it with this tip.
Old 01-14-11, 06:59 PM
jnguyen87
jnguyen87's Avatar
you would have to cut off the tips on your greddy. Then you wouldnt have anything tubing to slide the s2k tips onto...maybe have to weld some kinda tube onto your greddy "canister" then slide the s2k tips onto that?
Old 01-14-11, 07:01 PM
jnguyen87
jnguyen87's Avatar
it wouldnt look ghetto. it would look just like if you welded it on. Slide it on, tighten the bolt down. Welding it on wouldnt look any different, except possibly more "secure." So far tho no one as lost theirs due to tightening that bolt.
Old 01-14-11, 07:28 PM
KangstaxD
KangstaxD's Avatar
can't find it on ebay=(. Can someone chime in and help me T_T.
Old 01-14-11, 08:29 PM
J250
J250's Avatar
You DO NOT need to weld or drill hole. AP2 exhaust tips directly bolts onto our stock exhaust pipe. It's a sold fit on the exhaust. AP2 tips are a lot larger then the GFX tips. The only issue you are going to have when installing these is removing our stock exhaust tips. Just use some WD40 and rubber mallet to remove it.
I took pictures of my AP2 tips that i just bought last week. Gives you guys a good understanding of how the bolt on works.
Kangsta, I would suggest you searching used ones on honda/s2000 forums. If you're lucky you can get them pretty cheap for around $50-$80. Do not buy it from the honda dealership because its a rip off. I believe they sell it for nearly $300 for a set of new ones.
As for ebay, member: wheelcapaccessories sells them. Just email him to see if he has anymore in stock.
Old 01-14-11, 09:35 PM
laobo979
laobo979's Avatar
IDK about $300 new my Honda dealer goes for $120 a set... Kangsta http://www.hondaautomotiveparts.com/...5=EXHAUST+PIPE
Old 01-15-11, 01:54 AM
Jetfire
Royale with cheese
Jetfire's Avatar
$300 new sounds about right...in canada. where everything costs about twice as much.
Old 01-15-11, 07:49 AM
KangstaxD
KangstaxD's Avatar
Thanks for the help guys! I knew I can count on my Lexus brothers =D. I think I am going to get a pair from the honda dealer like laobo79 said. Thanks again!
Quick Reply: S2000 AP2 Tips?
