Hey guys ive tried searching but didnt get answers to my specific questions. So im about to add JL sub and JL amp to my car. How are you guys going about adding aftermarket systems to your cars? Are you running the wires thru the whole car to the front deck? are you just tapping into the rear speaker? And are you guys disabling the stock sub?
I added a sub and amp to mines.. let me know what u need. to get audio signal for the sub, you tap into the rear amp should be the wires farthest, closest to the end. i left my stock sub connected
Ok so I'm confused if I want to install a AMP and SUBs so do I pretty much tap the stock amp and sub?? Is that like a giant bridge??
i would try to explain it but i will do a horrible job compared to the DIY so just read and go through all the pages from last link i posted then everything will make sense... read post #9
So ive been reading and trying to learn how to hook up my sub and amp. Not as easy as it was back when i had an integra lol. Anyway, I see in the linked thread above that the ML guys tapped into the front door woofers. Is this because they have ML? In my case, a non-ML, would it still be beneficial sound wise to do that? or would tapping just into the stock sub sound just as good?
