55w or 35w 6000k HID's for fogs?
2007 IS250.. want the fogs to match the headlights (or have a little bluer tint because I might go bluer on the stock HIDheadlights)
http://www.ddmtuning.com/Products/Ap...Raptor-HID-Kit
question is which wattage to go?
Already have white LED's coming for the city lights... next on the list is LED's for Drl's (when i can get one that doesn't require drilling)
also- is this the best place to get them from? anyone have a different suggestion?
I've read all the threads about em, looking for updated info.
This LED DRL doesn't require drilling: http://www.v-leds.com/Vehicle-Specif...-p9371398.html
55W might be too high for the fog wiring, but I'll let someone else confirm that.
^ Yup, they're about a month old. I think I got the first set.
You can tuck the module and connectors entirely inside the moisture shield so it's totally plug and play. No drilling or relays.
Any ddm-tuning codes around?
Looking to get 6k HID's for the fogs tonight!
Last question, I think you've answered this for me before. Stock HIDs = 5k right?
I have a number of DDM kits. Here's my experience
55W kits always wash out more of the color than 35W. Note that the factory HID is 35W. If you plan to run 55W, always use the external wiring harness as a precaution. I actually recommend it for 35W kits too because the startup draw is pretty significant at 6amps for factory wiring.
For the OEM foglights on the IS, I'd do 35W. Color matching will be difficult because of the different brands.
55W 5000K is pretty much pure white (Mazdaspeed3 Headlights)
55W 3000K looks slightly yellow when looking at it directly, but shines much more yellow on the ground. (Mazdaspeed3 foglights)
55W 6000K has a slight blue tint (NSX headlights)
35W 4500K has a slight blue tint (though I've read that DDM actually sends out 5000K bulbs for 4500K orders, but I don't know for certain). In any case, the 35w 4500K bulbs I had looked similar in color to the 55w 6000K bulbs.
Below is the 55W 6000K lowbeam (right) compared to the factory Halogen high beam (left)
