LC 818 & Coilovers ?
Old 01-17-11, 01:47 PM
Kybball#1
Kybball#1's Avatar
Default LC 818 & Coilovers ?
For those of you rolling on the 818s and have coils, how low are you guys, did you have to do any fender mods. I just put my BC coils on and am right at about 0 finger gap, rears are fine but fronts are still rubbing when hitting a dip or bump, do i need to raise my front some?
Old 01-17-11, 01:58 PM
brociouz
brociouz's Avatar
Try rolling/shaving and heat gunning the fender liner before you raise.
Old 01-17-11, 02:22 PM
Kybball#1
Kybball#1's Avatar
Bro, how low are you, what did you do to yours? I dont want to slam it at all just 0 finger gap with no rubbing..
Old 01-17-11, 02:31 PM
montgb
montgb's Avatar
I'm at no finger gap with rolled fenders in the rear. I rub on sharp turns and dips in the front, but have gotten used to it. There's not much you can do except push back your fender liner.
Reach out to Damaster32 - he's the dropped the most on LC818s.
Old 01-17-11, 02:34 PM
Sffd103
Fire Slayer
Sffd103's Avatar
and dont worry about the swoooshing sound. That's just your tire rubbing a hole through the liner....that's the Low Life!!It'll get torn!
Kybball#1
Kybball#1's Avatar
Mont, my rear is fine and i too and at 0 finger gap... If i raise it much more ill be back where i was with the springs and then there was no reason to put the coils on .. Mont, what is your damp set on?
Old 01-17-11, 02:52 PM
600rr05
600rr05's Avatar
as others said above also maybe see if you can stretch a smaller tire.
brociouz
brociouz's Avatar
Same as you, zero finger gap. I did this to mine: https://www.clublexus.com/forums/is-...-on-coils.html
I suggest rolling your fronts ASAP. And you have to push the liner back, or just rub through it.
Old 01-17-11, 04:18 PM
Kybball#1
Kybball#1's Avatar
I cant find anyone in my area that rolls fenders.... grrrrr
Old 01-17-11, 04:27 PM
laobo979
laobo979's Avatar
True that a roll fender and a little stretch to the front you'll be aite. If you want probly stiffing the front dampner to see if that helps.
Old 01-17-11, 06:05 PM
Kybball#1
Kybball#1's Avatar
what is everyone on BC running there damping at? im 22/18 at the moment.
Old 01-17-11, 06:34 PM
montgb
montgb's Avatar
On my Tanabes, it's set to the middle (although I might go stiffer in the front).
Don't raise your car. If it becomes too annoying, use a heat gun to push back your fender liner and grind back the metal tab that sticks out. For the record, I haven't done either of those. The sound of my front lip grinding on driveways is more worrisome than the occasional rub.
Old 01-17-11, 07:42 PM
llamaboiz
llamaboiz's Avatar
hang on, if you raise your car you will push out your wheels more causing more rub, if you lower your car more it will increase the negative camber thus less rub...
you must go lower to not rub
Old 01-17-11, 08:39 PM
MashinA
MashinA's Avatar
^^LOL llama don't confuse him even more...
Old 01-17-11, 09:51 PM
JoshIS408
- - G T V I P - -
JoshIS408's Avatar
i think for the most part everyone rubs in the front if u are at 0 gap or less
Quick Reply: LC 818 & Coilovers ?
