slamming in the process. PLEASE help.
New to this game.
Need some help.
I want to keep it simple.
VOSSEN 083
20x9 front/ running 245/30/20... I believe OFFSET is +40.
20x10.5 rear/running 275/30/20 I believe OFFSET is also +40.
I think I will be ok in the rear once I drop, or will I have problems? please let me know
right NOW my front rims have 245/30/20.. as you would guess... I RUB.
Which isnt exactly a problem since I plan to slam but I am on STOCK suspension right now so slamming isnt an option.
I am selling the two front tires. 245/30/20 Falken 452's
My question... What tire should I replace with to slam![Uhh...](https://www.clublexus.com/forums/images/smilies/1387914497.gif)
If I want to drop with coils and have 0 fender gap Do I run 225/35/20 or 235/30/20 ?
Thanks guys.
Need some help.
VOSSEN 083
Thanks guys.
ok so 225/30/20.. what tires would you recommend, I am running falken 452's up front which BTW I am selling tonight for $200. riding on stock front rights now. I hear it good to have all four matching tires but also hear its ok as long as the axle has the same tires on both sides,
Recommend me some 225/30/20 tires please
![Woot](https://www.clublexus.com/forums/images/smilies/woot.gif)
BC Coils are the best bang for your buck! Everyone runs them and the ride quality is better than stock. Talk to Tristan at CircuitMS.....hes a vendor on here. He will take care of you and answer any questions you might have. I was running 225 on my setup and I switched to 235, depending on where you live and how good your roads are I would go 225 or 235. Both are good choices.
My front is 9inch +38 rear is 10.5 +42
so u know am going to bombard you with questions right
are u on vossens? how low/fender gap were you? when you 235 u only rubbed in the front slammed? did you roll any of your fenders?
Yes I am running Vossens CV1. I have no fender gaps..Im pretty much tucked all around. I had to roll the rears though to tuck. You can go 1/2 a finger in the back with no roll and 275/30. I was rubbing at first up front and I took a heat gun to the liner and just worked it up about an inch and its great. No rub what so ever and I have no negative camber.
damn sounds like I will end up following your foot steps if you dont mind friend.
That makes me happy as I dont have to sell the 275 rears just a small rolling of the fender if I want to tuck.
Maybe running 225/30 I wont have to mess with the liner up front, what suspension are you on?
